Evans Water pump GP
Old Mar 6, 2004 | 12:40 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
I had the o-ring & gaskets with my shipment - and yes, since I was using the 760 belt w/the ASP - I went with the 755 belt as per Nate.
Don't forget - if you're NOT running the Evans coolant - you must remove the WP pulley and take out the small pipe plug that is installed in the factory weep hole by Evans.
If you ARE running the Evans coolant - you must take xtra special care to drain all the original Dexcool type out of the ENTIRE system. The guy at Evans recommended removing the block plugs to completely drain the block and use Prestone Flush kit 1st then flush w/just water the fill with the Evans.
Old Mar 8, 2004 | 12:02 PM
Nasty N8's Avatar
Cool good to hear you got them OK.
Thanks Nate
Old Mar 9, 2004 | 05:20 PM
Nasty N8's Avatar
Got some more out today.
Thanks Nate
Old Mar 9, 2004 | 07:27 PM
1QUIKWS6's Avatar
Nate-
Did you get my core I shipped to you yet?
-Jay-
Old Mar 10, 2004 | 09:51 AM
Nasty N8's Avatar
Your core arived yesterday thanks.
Nate
