Power steering pulley alternative
Old Feb 15, 2011 | 01:10 PM
91FormulaKiller's Avatar
Default Power steering pulley alternative
Has anyone successfully run a 2004 Pontiac Montana 3.4 L power steering pulley GM part# 10166335 on a 98-02 F-body LS1? I know this may be a simple part but it has holes in it for easier access to the pump and is way cheaper @ local parts stores, under $20.
Old Feb 15, 2011 | 07:38 PM
Well, i bought one, results to be concluded at a later date.
Old Feb 15, 2011 | 08:23 PM
S10xGN's Avatar
There's a huge thread here about which pulleys fit and which don't, search is your friend!
Old Feb 16, 2011 | 08:18 AM
Your exactly right and im the last person to ask something before searching for 2 hours 1st, i did not find a definitive answer to my question, try it out for yourself, search "power steering pulley" in Gen III external engine or any of the categories for LSx.
Old Dec 26, 2013 | 12:46 PM
I've gotten PM's about this asking if it works the past couple years so i figured I'd throw it out there that this does work out very well, belt length may need to be changed!
Old Jan 27, 2017 | 02:16 PM
Just adding this, if you run all stock LS1 accessories/pulleys (F-body) and use this 3.4L Montana steering pump pulley you will need a serpentine belt that's 78 inches long. Example being a Duralast belt Part # 780K6 (the 780 represents 78.0 inches 6 = 6 ribs) will work.
Old Jan 27, 2017 | 03:31 PM
OwieVT's Avatar
The billet one from Turn One is a very nice piece and makes removing both the pulley and the pump much easier. I know it costs more but well worth it to me.
Old Jan 28, 2017 | 12:54 PM
01ssreda4's Avatar
The stock pulley is plastic......drilled a hole in it! Also, how many times do you remove it? Worth the hassle of now having to remember a completely different belt length, nope not for me. Ive removed a bunch of power steering pumps and all i ever used was a ratcheting wrench and did a couple turns on each bolt switching back and forth a couple times and it was in my hands. Seems simple enough. The pulley doesnt have to be removed to remove the pump.
