Cats or No Cats? Need some input.
Old Feb 17, 2011 | 09:40 PM
MI-Z/28's Avatar
Question Cats or No Cats? Need some input.
Car is an '02 Z28 and is my daily driver for six months out of the year. Since I currently live in Michigan it does not undergo visual inspection or emission testing every year, so originally I was set on getting an ORY. However with the job market the way it is my location could change in the near future. Now I'm leaning towards getting a catted y-pipe, but still plan on ditching the AIR. I'm torn because of the extra cost of a catted y-pipe and friends of mine have had issues with aftermarket cats in the past. What are your thoughts?
And how is the smell of a vehicle without cats? Is it comparable to a 4 stroke dirt bike, jetski, 4-wheeler, etc. or worse?
Finally, if I do decide on getting a catted y-pipe I was looking at American Racing 1 7/8" LT's. How are the cats that they use on their y-pipes? Anyone have or hear of any issues with them?
Old Feb 18, 2011 | 01:23 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
You should be fine. You'd probably be hardpressed if you moved to CA or NJ. But you can always find someone in either state that could "help" you pass. Ive bee CATless for 5 years or more. ..
... Doesn't smell bad. I hardly ever notice anymore.
Old Feb 18, 2011 | 03:39 AM
TORCHD 02 TA's Avatar
Go catless man.. It's the only way to go (if you don't have to under go an inspection)
And I have a cam in my car.. I will tell you I smell like fuel when I get home
Old Feb 18, 2011 | 03:58 AM
LPE 403's Avatar
IMO, smell should be the least of your concerns. The low risk of a 'possible' aftermarket cat problem will never out way the sound of *** that only a catless Y can make. Stick with the better brand of header/Y manufacturer's and your cat failure risk should be decreased. Sound is of course subjective....but then again, I would challenge anyone to convince me that rasp and deceleration "popping" is cool. Lol, for the 5 extra hp, no thanks.
Old Feb 18, 2011 | 04:09 AM
Chief Z's Avatar
Unless you are planing some serious internals, stick with cats. Less problems all around. I have had it both ways, and the potential benefit from running an ORY vs the emmissions hassles dont balance. Find some good quality race cats and you have no worries.
Old Feb 18, 2011 | 05:01 AM
omarrakeen's Avatar
i went catless since we have no emissions here..but in your case id go catted since you might deal with emissions. i hate welding cutting bla bla every year! my car doesnt smell bad at all unless u stick ur nose to the tip
Old Feb 18, 2011 | 05:10 AM
jsteele90's Avatar
i highly recommend a set of high flow cats. my wife wouldnt even ride in my car when it was catless. and it stunk to high hell all the time.
Old Feb 18, 2011 | 05:11 AM
That jsut means more time for your self
Old Feb 18, 2011 | 06:29 AM
ncsu602's Avatar
Mac mid lengths, cat-less Y (well, gutted hi flows), and a flowmaster merge. I have absolutely no rasp or popping. I can tell you with a slightly rich tune and a cam it'll smell. I have a basement garage and I have to pull it, if I back in the hvac unit pulls the fumes in and smells the ENTIRE house up for 30 min.
I'd probably go with some good flowing metallic cats if I had it to do over again. Should help with the smell and not lose too much power.
Old Feb 18, 2011 | 07:37 AM
senicalj4579's Avatar
No cats. Period
Old Feb 18, 2011 | 07:54 AM
BigBirdLS1's Avatar
My vote is go with cats because they are sooo much better than dogs LOL. But seriously guys I have tru-duals with no cats and a cam. I have 0 fuel smell at all. I have really never smelled fuel with any car that didn't have cats. Maybe I'm just immune to the fuel smell. Oh btw my car is on a nitrous tune too running pretty much 11.3-11.5 on motor all the time and noone has ever said "your car stinks" just my .02
Old Feb 18, 2011 | 08:37 AM
Benjamin Russick's Avatar
Eh. To me, it is worth it to run cats. Virtually no loss in performance, no inspection hassles and helps the PC aspect of our hobby.
FWIW, my 2000 Z28 with a 382/nitrous engine had no cats and you definitely smelled like "car" after driving it...
Old Feb 18, 2011 | 10:42 AM
pimpjames's Avatar
I have a top end kit and a bunch of bolt ons. I have an appt. to get my exhaust redone on Sat. With the off-road Y-pipe + Headers and no cat the sound is rediculous.... I can't even drive it in the mornings do to the sound. It is VERY "Poppy" and with the 3800 stall stays in that range most of the time. I am getting it swapped out with a H-Pipe and true duals to hopefully resolve it. If not ill add resonators .
Cliff notes: I vote keep the cats with a Y-Pipe
Old Feb 18, 2011 | 10:46 AM
wreckwriter's Avatar
My car picked up 3/10 in the eighth mile when I dumped the cats.
Old Feb 18, 2011 | 11:19 AM
Golf&GM's Avatar
^^ Those must've been some horrible/clogged cats.
Old Feb 18, 2011 | 04:42 PM
35th camaro's Avatar
i drove mine 1 days with no cats, almost got tiketed(loud) and i smelled like exauste fumes, made us sick from fumes when working around it, put cats and mutch better, i did like the sound with the cam 236-242 in my 402, sounded like a drag car on the streets. cats brought the sound down to a tollerable level.
Old Feb 18, 2011 | 04:48 PM
The Manalishi's Avatar
Get some good aftermarket cats and you'll have no worries.
Old Feb 18, 2011 | 06:47 PM
MI-Z/28's Avatar
Anyone have any recommendations on which aftermarket cats to get? How are the cats that ARH uses on their y-pipes?
Old Feb 20, 2011 | 08:52 AM
They were Kooks "high flow" cats with about 10k miles on them.
Old Feb 20, 2011 | 08:55 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Which, unless they changed something, are not metallic core like you should be using for a forced induction application.
