No spark and injectors aren't pulsing. Ideas?
Bought the car as a roller. Installed a built LQ9 with magnacharger. Used factory harness. ECM has been programmed for my setup. I'm not getting spark and the injectors aren't pulsing. I do have pressure at the rail. I've swapped the ignition relay and changed the crank sensor. The 3 wires that ground to the drivers side head were initially grounded to the block. I didn't think that was an issue, but I pulled the supercharger and swapped them to the head. Still no luck.
^ Was gonna say that too. If the PCM doesn't see the engine cranking, pulse the injectors or energize the coils. (even though they're a ground switch)
After taking everything apart trying to figure out what I missed, I borrowed a different PCM and it fired right up. Didn't let it run because it wasn't tuned for my car. Tried my PCM again and it still doesn't fire, so it looks like i just have a bad PCM. Just ordered another on eBay and should have it in a few days.
