FAST 90mm intake and stb clearance question
Old Feb 15, 2004 | 08:17 PM
11 Bravo's Avatar
Default FAST 90mm intake and stb clearance question
If the 90mm intake shows good gains on strokers after the tb comes out (not spending $ blindly), then I will get it. I have a Hotchkis stb, and I think it sits lower to the intake than the others. How much higher does the 90mm fast sit than a LS6? Just wondering if I will need a different stb. Thanks!
Old Feb 15, 2004 | 10:36 PM
WILWAXU's Avatar
It's not more than a inch or 2 higher than the LS6, if that. All strut tower braces I've seen for these cars are nearly even with the cowl... should clear by a mile.
Old Feb 16, 2004 | 12:16 AM
SMOKIN01TA's Avatar
the hotchkis will be iffy. mine sits about a inch off the ls6 intake if i recall right maby a littl more but its under the cowl
