New MAP sensor gasket
Old Mar 11, 2011 | 02:12 PM
adrynalinjunkie's Avatar
Default New MAP sensor gasket
I bought this car with a FAST 90/90.
I just removed the GM MAP and the orange rubber gasket is shot. This must have been causing problems.
Is there a better replacment rubber gromet out there or should I just go to the parts store and then the dealer?
Old Mar 11, 2011 | 05:41 PM
Pocket's Avatar
GM sells it attached to the sensor. Best bet is a junkyard. Most new MAP sensors use the same grommet, steal one from them
Old Mar 11, 2011 | 08:44 PM
Even worse GM says it is part of the intake manifold! Would I truck manifold have a usable gasket?
I guess I can go see in the bonyard tomorrow.
Old Mar 11, 2011 | 08:45 PM
O2Form's Avatar
Look on Fleabay, you can buy a new map with the gasket under 20 dollars.
Old Mar 11, 2011 | 09:03 PM
Pocket's Avatar
Yes a truck intake will use the gasket. Econo V6's in the JY will be quite a bit easier to come by and most have the new MAP sensors which use that grommet
Old Mar 11, 2011 | 09:39 PM
Thanks for all the idea's I will check fee bay, better than spending time Saturday afternoon at the nasty azz local bone yard. With all the smart folks.
Old Mar 11, 2011 | 09:44 PM
sjsingle1's Avatar
you can buy the rubber gasket separate.......ask me how i know
Old Mar 11, 2011 | 09:45 PM
sjsingle1's Avatar
pn 16194007......got em in 1 day from my dealer
Old Mar 12, 2017 | 06:25 PM
BennyB's Avatar
Don't mean to bump an old thread, but this thread saved me some money from buying just the seal and not the whole sensor.
