VMAX Velocity Ring. Using 90-92mm TB on FAST 102 Intake
Turd Gen Guy
So, what is the best setup if you have to start from scratch?? I have the new 102 intake, CNC'd 205 AFR's, bigger cam (230/234 .614 with a 114lca). I need to buy a new TB and MAF, what is the best way to go?? Any thoughts Mike?? Just point me in the right direction and I will order ASAP.. Thanks in advance
Good info for the most part here and just know that too much TB can hurt the low end and tip in quite a bit and even cause a loss on top.
Mike Norris
Yes back from the dead
but that's what happens when you use the search function. Just got a ported FAST 102mm lsxr intake. So I'm building a 5.3 turbo motor. Thinking the 102tb is too big for those small cubes on initial tip in. Is my best option the fast 92tb and the vmax ring or is the ring not necessary with that tb? Would it be too hard to tune the 102mm tb?
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
I've got a ported 102 by Mamo. Didn't want to spring the coin for a 102 TB so I had Tony also port the LS3 TB. Added the velocity ring as many have said it helps the transition. Supposed to make tip in and tuning easier. Tony confirmed and for the money I didn't feel bad about the purchase. If it was snake oil people have spent more for worse.
I just buttoned my build up yesterday. Will be working the tune with Pat G over the coming weeks as break in is complete. Then I'll get on a dyno.
Bottom line I've heard good things and some very reputable folks recommended it. For the price I paid no complaints. Only way to know for sure though is a before and after comparison but my build is a totally new engine so can't give that. Car is running pretty good so far though.
ERL 427, 11.5:1, TFS GenX 255, FAST 102, etc. all motor with road race friendly cam.
Originally Posted by NAVYBLUE210
Travis
Looking forward to your results. I have the V Max ring for my
Build also.
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Build also.
On the V Ring, I forgot Mike Norris was another one recommending it. Also a lot of guys on Corvette forum reported good results as well.
