Ls6 intake egr adaptor questions
Old Mar 22, 2011 | 03:07 PM
TROYCO's Avatar
Default Ls6 intake egr adaptor questions
I'm looking for anyone who has ever had experience adding an EGR adaptor to their LS6 intake or who has one of the intakes from SLP. (Now before I begin, let me just say that deleting my EGR is not an option. Been down that road, have to have emissions tests every 2 years, visual inspections are done randomly, and I will not face the consequences of being caught without it. Nor do I wish to change intakes every time i have an emissions test, as it's a colossal waste of time) I'm thinking of adding a brass fitting to it and i was just wondering how it is secured onto the manifold? Also, exactly what size of fitting is needed? Searching has proven fruitless for me so hopefully somebody has an answer. Thanks in advance.
Old Mar 23, 2011 | 01:03 AM
mikey67's Avatar
I'm looking into this at the moment. After some searching and looking at pics of SLP's LS6 intake (haven't had the opportunity to see one in person) I'm looking into using a "Ferulok" style fitting made by Parker. This seems to be similar to what SLP used and is readily available. ...I don't know if it's compatible just yet but I will be confirming this in the coming weeks when I pull my car out of storage and have some time to take a look at them.
Old Mar 23, 2011 | 06:12 AM
TROYCO's Avatar
I've also seen a similar style fitting at home depot...i may even give that one a try.
Old Mar 28, 2011 | 05:28 PM
joe77's Avatar
looking for a solution too, I have had the intake for awhile now, but was waiting to do emissions to put it on lol.
Old Mar 28, 2011 | 09:46 PM
TROYCO's Avatar
apparently SLP discontinued it.
Old Mar 28, 2011 | 10:00 PM
MjMaro's Avatar
I had this intake on my old motor, this should help you guys:
http://www.jegs.com/InstallationInst.../847-30041.pdf
Old Mar 28, 2011 | 10:51 PM
joe77's Avatar
Appreciate the link, I wonder if brafasco would have anything like it. i was also wondering if you could simply run it to one of the vaccum ports on the side of the manifold behind the tb. Like run a hose off of it, to an adapter then too a smaller hose that connects to the manifold. Would there be any tubing that could withstand the heat? How much pressure does it have?
Old Mar 29, 2011 | 04:00 PM
patSS/00's Avatar
Probably not a good idea unless you like putting exhaust gas into your crankcase.
Old Mar 29, 2011 | 08:42 PM
joe77's Avatar
Oh? the side ports are used for the pvc? Do they not suck in air?
Old Mar 30, 2011 | 02:33 AM
patSS/00's Avatar
One port lets fresh air into the crankcase, wouldn't want to hook to that. The other is to draw crankcase vapors into the intake via the PCV valve, so as long as you hook into the intake side of the valve that might work, but it might cause the valve to stay open more (less vacuum on the valve with EGR open). I think there's a reason they designed it with the EGR inlet after the throttle body where the PCV lines hook in.
Old Mar 30, 2011 | 10:27 AM
TROYCO's Avatar
i've made a bit of headway. i bought the same swagelok fitting slp used on their manifold and i am just trying to find a good epoxy to use. i think i may make a write up about how to make it if it all turns out well.
Old Mar 30, 2011 | 08:10 PM
tpunk's Avatar
I want to see how this works out so "subscribed".
Old Mar 30, 2011 | 11:37 PM
joe77's Avatar
please let us know how it works out, I will be doing the same if it does, still hesitant to drill into it lol.
Old Apr 1, 2011 | 10:02 AM
jg rider's Avatar
See if this will help. This manifold has a hole in the back,and I can't find anybody that in my area that does plastic welding .
Old Apr 1, 2011 | 12:23 PM
mikey67's Avatar
Thanks for the pics JG.
...Looks like the fitting mounted to the intake snout has been machined a bit to be more flush with the intake opening.
Old Apr 1, 2011 | 12:54 PM
jg rider's Avatar
Is this what you mean ? There is no way that I can get a wrench around it to loosen. I spoke with SLP a little while ago and I was told that the price that GM wanted for the L6 manifolds was too much to justify modding and then selling them
This is what I have for #'s. I don't know if other #'s were used
Old Apr 1, 2011 | 01:13 PM
mikey67's Avatar
Yeah, that hex is much thinner than on any compression fitting I've seen, looks like it's been turned down a bit. Wouldn't take too much to duplicate this.
Old Apr 1, 2011 | 02:51 PM
TROYCO's Avatar
it also looks like they used some sort of thin washer between the epoxy on each side as well. as far as nuts, i've found that a 3/4" lock nut found in plumbing or electrical stores could be used, as it's already really thin. all i need to figure out now is what kind of epoxy to use. i picked up some jb kwik, so unless i find something better, that's what i'm gonna use. any thoughts?
Old Apr 1, 2011 | 03:02 PM
99huggerorangeZ's Avatar
very interested in this,subscribing
Old Apr 1, 2011 | 04:15 PM
jg rider's Avatar
Talking to SLP I was told that they had to use epoxy because of vacuum leaks and I wouldn't be able to loosen up the fittings.
Did anybody see this post I made a little while ago
https://ls1tech.com/forums/generatio...g-removal.html
I wonder!
