MAF? custom making 4" MAF for LS1 if possible.
Subscribe
Mar 31, 2011 | 06:39 PM
Is it possible to take a ls7 MAF and place it in a 4" aluminum pipe and it work ok? Was thinking of a way to make one to match up to my 101mm TB. It Just don't make since to have a 101mm TB and intake and not have a big MAF to go with it. I guess I could look on AllData and see if the pins are the same. Maybe someone here has already tried it or no someone who has. Thanks....
Reply 0
Mar 31, 2011 | 06:56 PM
Well, I did just find something out. The 07 Vette uses a MAP sensor also. Kinda like the old GM 2.8 and 3.1 that uses bot MAF and MAP. The Vette has a 5 wire sensor where as my 00 LS1 has only three. The LS1 uses a A,B,C, connector and the Vette uses A,B,C,D,E,F. Comparing the two A,B and C are the same. A is signal, B is ground, C is power. Thinking maybe, find a 5 wire connector in the salvage yard and only use the three. Ya'll think it would work?
Reply 0
Mar 31, 2011 | 07:07 PM
texas speed makes a 100mm mass air...
Reply 0
Mar 31, 2011 | 07:45 PM
Quote: texas speed makes a 100mm mass air...
After lookin at that one it looks like my idea will work. That's what there using; a 5 wire sensor with a 5 to 3 adapter. Thanks ls1curt for turning me on to that.
Reply 0
Subscribe
