Who went from ORY to catted Y?
Old Apr 6, 2011 | 10:41 AM
01formula6's Avatar
Question Who went from ORY to catted Y?
I've had my Pacesetter LT/ORY/Hooker combo for a good 5 years now and do like the way it sounds. However, I'm also 5 years older now and it can be a little loud for daily commuting to work. I know you can weld in cats or a bullet, but I'm considering getting TSP's newer catted Y. This way I still have my ORY if I want it, plus I get the better FM merge.
Who has been in a similar situation and made this switch? Exhaust sound is subjective, but did it quiet things down enough to make it "worth it".
Old Apr 6, 2011 | 10:57 AM
FNSlow's Avatar
I just welded in cats to my ORY. I couldn't see myself changing the Y-pipe often.
Old Apr 6, 2011 | 10:58 AM
93SlowBird's Avatar
What he said
Old Apr 6, 2011 | 11:33 AM
VegasWS6's Avatar
I have the new style TSP catted y and I love it. It replaced a hooker ORY on my car and it helped to mellow out the exhaust. The rasp was eliminated and the car has a slightly deeper tone. All in all I'm glad I did it and I couldn't be happier with the sound. Just as a warning if your car is lowered you may experience some bottoming out on the cats and have to replace them.
Old Apr 6, 2011 | 12:42 PM
MikeWS6's Avatar
TSP Catted Y pipes kill all the rasp. If my car was a track only car I would just get an ORY.
Old Apr 6, 2011 | 01:29 PM
c0ncEpT's Avatar
A friend of mine went through the same thing.
He went from:
LT, ORY, Loudmouth
LT, ORY, Borla
LT, ORY, Hooker
And he finally ended up with
LT, ORY(FM Merge), cutout, and stock catback
Here is a video of his exhaust. Just some food for thought
Cutout closed the entire time
http://s5.photobucket.com/albums/y15...t=MOV04053.mp4
Cutout opened a few seconds in
http://s5.photobucket.com/albums/y15...t=MOV04055.mp4
Old Apr 6, 2011 | 01:43 PM
brians91formula's Avatar
The reason I don't go to a catted Y pipe is because i'm afraid to lose horsepower. Anyone know how much power is killed by going through high flow cats ?
Losing 1-2hp would break my heart
Old Apr 6, 2011 | 02:51 PM
01formula6's Avatar
Thanks for the opinions so far. It's sounding like those of you who switched to a catted Y do think it made a worthwhile improvement. My car is a DD for 8 months per year and rarely sees the track, so it looks like cats are the way to go now.
Concept, your friends car sounds a lot more beastly than mine even with the stock catback, lol. I like the sound of my Hooker, just need to reduce some in cabin noise.
Brian, from what I've seen a catted Y will cost you less than 5hp, which I will probably gain back by having a FM merge. I'm not really concerned about it.
Old Apr 6, 2011 | 02:58 PM
TImmy_Jones's Avatar
Put a cutout in the I pipe and then a bullet muff right after. Loud if you need it.
You will lose a few hp with te hi flow cats according to everyone on here.
Old Apr 6, 2011 | 03:32 PM
MikeWS6's Avatar
You will probably lose around 3-5 hp with cats. Nothing you would even notice.
Old Apr 6, 2011 | 03:37 PM
justin hover's Avatar
a couple of -hp for the sound quality your looking for is a fair trade.
Old Apr 6, 2011 | 03:43 PM
MattxFatal's Avatar
I started with a first gen TSP Y.
**** my ***, it sounded so terrible.
Had it cut up and made into a custom ORY with an FM-merge.
Sounded better, still not where I wanted it.
Added Thunderbolt metallic-core cats, MUUUUCCCHHHH better.
It will be getting a little more work done to it here soon.
-Matt
Old Apr 7, 2011 | 07:38 PM
Raise's Avatar
Id be more worried about clearance than hp loss. There is just no good room for cats under our car bodies. Even at stock ride height it robs a bunch of clearance
Old Apr 7, 2011 | 11:06 PM
RevGTO's Avatar
Pontiacerator
Passenger side is fine; the driver's side is definitely a problem.
A catted Y w/FM merge was a big help in quieting my GMMG and killing rasp after adding LT's.
Old Apr 8, 2011 | 10:11 AM
01formula6's Avatar
That's for all the feedback everyone. It sounds like the catted Y will give me exactly what I'm looking for. I'll be picking one up shortly.
Old Apr 8, 2011 | 10:41 AM
ncfastls1's Avatar
lol. I'm not sure if it makes a difference what cats Kooks uses in their y pipe (I'm pretty sure they are magnaflow), but I sure as hell am not losing any power. Check my sig and you'll see I'm making more power than most with the same mods with ORY.
Old Apr 9, 2011 | 06:55 AM
jsteele90's Avatar
i started with a TSP ORY with a 40 series flowmaster. sounded good at idle thats about it. then got some hi flow cats welded in and a dynomax 3'' bullet muffler and i couldnt be happier. no rasp, no droning, no stinky car!!!
Old Apr 9, 2011 | 07:00 AM
allbaugh_04's Avatar
All this cat talk with no sound clips
Old Apr 9, 2011 | 10:25 AM
n2oblkz's Avatar
I have long tubes, ORY and a GMMG. I also have two Magnaflow bullet cats in the garage getting ready to go into the Y pipe.
