Why Ls1 fuel rail will not fit with FAST 102 intake
FAST 102 intake in the way and i want to know why i could not fit my LS1 fuel rail ?
some body told me i haven't to buy LS2 fuel rail all i want to do is to cut the center section between two sides and connect a hose with clamps instead of the removed metal part.
Is this the onley problem ( the metal center section between both sides or there is some thing else make it not fit ?
Any help will be appreciated
Hes right, the mounting tabs are in different locations.
Dont hack up your OEM rail, youll burn down your car. Youve spent a ton on your engine so far, why not just buy the correct rails at this point? I see LS2 rails go for $50-$100 all the time.
What injectors are you planning to run?
Kleeborp the Moderator™
Tell them they are an idiot.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
