Installing Flowtech headers
Old Feb 20, 2004 | 07:23 AM
NBM2001z28's Avatar
Restricted User
Default Installing Flowtech headers
Tonight, it begins i should be able to write up on it a little saturday or something. Look back here for how it went i'll edit this post.
*************EDIT**************
Ok they're installed. it wasnt that bad really. I had to take out the steering rod to get the driverside header in and drop the starter with the passanger header. Other then that it was basically straight forward. everything went fine and they look great. I want to get the car dynoed on the 6th but i dont know if thats going to happen because tom at speed inc said they werent planning on dynoing any cars. the y-pipe went up really easy to the headers too, that itself probably took 10 minutes. For what i paid im rather happy
Old Feb 20, 2004 | 08:36 AM
NovaTime's Avatar
make sure you tighten them after a 30 mile period or so. I installed them on a '94 truck, and they needed to be tightened after a couple days driving them.
Old Feb 20, 2004 | 08:43 AM
The_Snyper's Avatar
So this must mean you have them in your hands now. How do they look? Quality? Comparable to the Hookers?
Old Feb 20, 2004 | 10:14 AM
NBM2001z28's Avatar
Restricted User
Ok here's my review on the headers quality blah blah. For the price that they cost im happy with them. There is a little texture to the pipes and they're kind of scuffed up. I'm not really worried about that though. the y-pipe is flattened in some areas which i figured it would be when i bought it. I'll take some pictures of the flattened areas tonight before i put it on. I'm going to be posting pics of thea headers and the y-pipe and after they're bolted up etc. these are the first actual ls1 headers i've seen but im sure they dont compare to the hookers or a $600+ set of headers but that's expected. the only thing that im worried about is blowing gaskets since they're not slip fitted headers. I'll find out and just hope i get the bolts tight enough where they wont blow gaskets.
Short version - they are basically a lower quality hooker, i was told they have the same bends and the same design, its just that hooker is slip fitted.
Old Feb 21, 2004 | 09:29 AM
NBM2001z28's Avatar
Restricted User
To the top
Old Feb 21, 2004 | 10:43 AM
demonspeed's Avatar
It's not mine! woo hoo!
pics????
Old Feb 21, 2004 | 05:36 PM
NBM2001z28's Avatar
Restricted User
http://community.webshots.com/album/120041128UKEXQq
Pics
Old Feb 21, 2004 | 08:10 PM
foff667's Avatar
LS1TECH Sponsor
wow no offense but they look like trash JMO dented header tubes right out of the box and all...paper thin flange...ahh get what ya pay for i guess oh wait ive got pacesetters mine must be shitty too let me look for some dents
 Michael S. Palmer
Old Feb 21, 2004 | 09:34 PM
2xLS1's Avatar
Looks like they dented the primary tube where some have to grind the K-member for clearance. The last set of Pacesetters I installed had to have a tube dented in addition to grinding the K-member.
Old Feb 22, 2004 | 12:06 AM
foff667's Avatar
LS1TECH Sponsor
i took off about 4mm from the kmember w/no denting of any primaries i dont see dents being the best fix for header tubes, maybe its me
Old Feb 22, 2004 | 06:05 AM
Fred99LS1's Avatar
I personally won't buy them now after seeing the primaries dented like that. If I wanted a 1 5/8 header I'd buy one. Nope I gotta have un-dented primaries. Guess I'll keep shopping, Just my .02, Fred
Old Feb 22, 2004 | 07:44 AM
4thGENRETARD's Avatar
Check out Bassani mid length.
Old Feb 22, 2004 | 09:25 AM
jrp's Avatar
jrp
SN95 Director
i dont see why then dented the primary , fitment is not exact so if it was for k-member clearance what about the guys that dont need knotching, there stuck with a dent primary?
the Y-pipe doesnt look to bad. are those ball flanges?
Old Feb 22, 2004 | 09:45 AM
99 Black Bird T/A's Avatar
My Hookers had several quailty issues like missed welds, 02 bung in the wrong place, primaries full of slag, flange wasn't flat, & the header wasn't bent correction so the Y pipe wouldn't fit unless it was cut apart and re-welded. In my experience Hooker quailty = however the Hooker design is excellent.
I'm glad to hear the install went well maybe one day I can put a set of FlowTechs on my wifes 02 Z.
Old Feb 22, 2004 | 09:49 AM
jrp's Avatar
jrp
SN95 Director
thats why you get jet hots
Old Feb 23, 2004 | 03:05 AM
GainesvilleLS1's Avatar
Uhhh... everywhere I've looked online they say Flowtech = Holley, not Hooker.
http://www.holley.com/HiOctn/ProdLin...FT/Header.html
Same company?? - edit: nevermind, I got it. Little slow sometimes.
Old Feb 25, 2004 | 10:23 PM
Svingos129's Avatar
Is your ORY coated? My dent primary doesn't look quite as pressed as yours...maybe its just the picture. I'm going to install in about 2 or 3 weeks.
Old Feb 26, 2004 | 10:23 AM
Brew02 WS6's Avatar
That's interesting if they predented the tubes where potential contact could happen because there's no way I would ever grind my engine block or K-member!!
Old Feb 26, 2004 | 10:28 AM
foff667's Avatar
LS1TECH Sponsor
I will repeat the same crap i said in the other flowtech thread
1. you dont HAVE to grind the block for a header install but its better than having to take out the steering shaft as this take about 1 minute with a sawsal
2. look at your stock kmember when you get a chance youll notice its already been cut and welded at the spot where your having to cut again...next everyone will be on GM's case for this
Old Feb 26, 2004 | 10:36 AM
NBM2001z28's Avatar
Restricted User
i bought the headers unaware of the dent, but it has been taken care of and thats why i went ahead and installed them anyways. My y is uncoated because i have a feeling there's going to be some cutting and welding to it so i didnt get it coated. i planned on having a cut-out installed so there wouldnt be a point. The headers have been good so far. i reused the stock steel gaskets also. the ones that came with the headers looked liek garbage and i wouldnt use them.
