*UPDATED With Vids *Mufflex catback with flowmaster, spintech or magnaflow muffler?
#81
You could put a Borla XR-1 #40086 (5"dia., 3.5" in/out, 15" case length)muffler in the I-pipe, but you'll need to clearance the drive shaft tunnel a little bit on the passenger side so the muffler will tuck up better, it's about $125. Or use a Moroso Spiral Flow(4"dia., 3.5"in/out, 12" case length) muffler in the I-pipe with no need to do any clearancing of the tunnel, about $55 steel(#94052), or $102 in stainless steel(#94056).Also a Dynomax #24216 (same size as the Moroso) about $48.
The dynomax and borla shouldn't affect the flow at all , the Spiral flow will effect it a little bit.
#84
http://www.summitracing.com/parts/MPE-14909/
would this muffler fit? Its much bigger than the one already on there
#85
