Fast 102mm with ls1 coolant tubes lots of pics
Old 04-27-2011, 01:22 AM
silverz28camaro's Avatar
Default Fast 102mm with ls1 coolant tubes lots of pics
I was wanting to run the ls1 style coolant tubes to help cool the rear cylinders and keep the heat out...After a little grinding it wasn't to hard to clear the lines. I also smashed the tubes slightly but they still flow, better then blocking them off IMO....
Old 04-27-2011, 01:24 AM
With the manifold apart i was able to look at the port match with my heads, to my surprise this manifold fits very well with the heads...I still found some areas to clean up in the ports though...
Old 04-27-2011, 01:25 AM
Old 04-27-2011, 01:26 AM
Old 04-27-2011, 01:32 AM
Other notes to add;
I used ls2 rails with ls1 injectors, the fast manifold came with all hardware, instructions, and the ls1/ls2 conversion o-rings
The MAP sensor in the rear fits very tight and close to my fire wall, I need to either dent the firewall in a bit, or install it to the front of the manifold.
I re-used my PTM 92mm TB for now, but it does not fit well, the PTM TB does not cover the entire "mouth" 0-ring, I used a little bit of sealant just to get me by until i get a 102mm TB.
I had to bend the trans dipstick over a bit to clear the fuel rail
Over all the manifold is very impressive and looks alot better, I just hope I can get 5-9rwhp from it...
Old 04-27-2011, 01:38 AM
kevin kuether's Avatar
You do realize that what you ground off the intake keeps it from distorting with heat. I personally wouldn't have done it but it was a good job.
Old 04-27-2011, 01:42 AM
Yeah I know, but really it wasn't that much material, I am not advising anyone to do it, I just wanted my rear steam vents to vent coolant instead of air pockets building in the rear where #7 is. The old fast manifolds did not have these ribs, and its not like i took them all the way down either. I'm sure it will be fine.
Old 04-27-2011, 01:46 AM
Zmg00camaross's Avatar
I think it will be fine. What you doing with the old FAST?
Old 04-27-2011, 08:41 AM
Mike with the corvette has it.
Old 04-27-2011, 05:14 PM
garygnu's Avatar
good work and pics.I just tapped my ls1 coolant lines down to fit under my fast 92.there is more room under a fast 92 intake.the fast 102 has alot more material in it,I believe it weighs 3lb more.other people with fast 102 intakes could use 2 vette coolant lines,one in back and connect it to the front coolant line .
Old 04-27-2011, 08:47 PM
Yeah I had a 92 before and did the same..tapped the lines flatter, not issues, but this 102 is a bit beefier and needed some minor work, I knew I was going to catch some **** on grinding it down, but I know it won't hurt it. I would like to swap over he the dual ls6 tubes, or a truck style might work. I mainly wanted to make sure coolant vents from the rear as well, It really helps keep #7 and #5 cooler if you do so.
Old 04-27-2011, 10:08 PM
bayer-z28's Avatar
Did you do an EVAP delete? I see an HVAC delete also. Drag car?
I'll add this link to my *General* FAST 102 thread.
Old 04-27-2011, 11:22 PM
Drag car, street car same difference, I drove it today to work, drag race it, drive it 100 miles to street race a 1000rwhp chevelle, drive it home, gets 22mpgs on the highway, closer to 11-12 in town with the converter....
All Emmisions are deleted but it still passes emissions... Thanks to some good tune work and not a to big of cam.
Old 04-27-2011, 11:26 PM
I have a/c delete, but I do have heat in the car...look closer at the two black lines running along the pass. side inner fender metal.. those go to a heater core I made from a old trans cooler/sheet metal shroud and a R6 cooling fan , works well to heat the car in 30 degree weather.. and it only weighs 5 lbs... the lightest I could get the heater setup.
Old 08-28-2011, 03:05 PM
fernadad's Avatar
hey man i have the fast 102 and FTP 104 lid, what MAF and coupler are you using? could never find the right combo to make it fit right, also what are the list of mods you have done to your car to clean up the engine bay, like EWP, ABS delete, etc, would greatly appreciate it!
Old 09-21-2011, 06:57 PM
I have a slp bellow that I had to dip in HOT water to make fit...also I use the 85mm MAF...IMO the maf is not a restriction.. the design of the manifold and runners is where the power gains are at.
Yes I did an electric water pump, manual steering rack, BMR alternator adj bracket. ABS delete, all emissions delete, traction control/cruise delete..a/c delete, smaller/ lightweight battery with a smaller motorcycle coolant overflow res.
Old 09-21-2011, 07:07 PM
Restricted User
z99ls1's Avatar
Clean looking engine bay!
Old 12-01-2011, 11:13 PM
fernadad's Avatar
hows it going bro, how did you do the fuel evap purge valve delete? i plan to do it but dont know what all to do? can you help me out
Old 07-03-2012, 05:09 AM
themealonwheels's Avatar
Bringing this back, hopefully for some insight on the FAST 102 rear cooling issue... I just modified my LS6 intake on my B4C to accommodate the LS1 steam tube setup. I realize my 2000 B4C doesn't have a "functional" temperature gauge (just a dummy gauge), but I swear it seemed like the temperature took longer to get to operating temp than with plugs in the back!
Well, now I'm thinking about my FAST 102 equipped 383. I currently have plugs on the back and the LS6 tube modified on the front. I have a spare LS1 crossover tube and I like the idea the OP had, mainly because I like the idea of hidden coolant lines for a cleaner look.
So my question, how should I go about smashing in the tubes? Any science to it, or a hammer on top of my LS6 valley cover? What about putting an LS6 tube in the back with the outlet closed to the banks can communicate but not evacuate to the radiator? That sounds bad, but would that allow enough coolant level to cool cylinder 7? A lot of questions here, any input on cooling the back cylinders is appreciated
Quick Reply: Fast 102mm with ls1 coolant tubes lots of pics
