alternator voltage is 18V!!!
Old May 1, 2011 | 03:20 PM
TROYCO's Avatar
Default alternator voltage is 18V!!!
just got my car out and noticed while driving it my volts jump up to 18 volts intermittently as opposed to the 13.8-14.3 it should normally sit at. it seems to only fluxuate between normal voltage and high voltage temporarily and then return to normal voltage. i replaced my alternator with a new one (not reman) last year so it's less than a year old. i suspect a faulty voltage regulator, but has anyone else had a similar problem or any other opinions?
Old May 1, 2011 | 04:32 PM
sjsingle1's Avatar
is that figure from the dash gauge....or a multimeter?
Old May 1, 2011 | 05:08 PM
TROYCO's Avatar
it's from the dash gauge, a scanguage II and a multimeter on the battery. all readings are consistent with each other.
Old May 8, 2011 | 01:09 AM
01ssreda4's Avatar
Sounds like your new alt is taking a ****.
