coolant crossover on back of heads instead of front?
Wondering if functionally it will serve the same purpose? I have a fuel pressure regulator mounted up front and would like to put that crossover in the back and plugs in the front but I'm having a difficult time finding info as to if this will still serve as a steam vent?
Thanks for any info ahead of time!
There are threads about this. Unfortunately, not all threads are easily found. You cannot substitute the rear for the front. The fronts need to be tied together & then run to a high point on the radiator, radiator top hose, top of water pump or high radiator auxilary box. If you leave the fronts plugged, the tops of cylinder(s) 1 & 2 will run hot. Engine is higher in the front than the rear.
The coolant manifold had a GM part number of 12562169 but it's long discontinued.
I say it's more important to have steam ports on the rear of the heads rather than the front.
The LT1 engine added ports to the rear of the heads.
These ports also help bleed air from the system.
That's not my engine, but same setup I got.
