Ditched the junk pacesetter y-pipe for this!!!
Old May 21, 2011 | 02:15 AM
98z8uup's Avatar
Nice work. Looking for sound clip soon.
Old May 21, 2011 | 01:26 PM
libertyforall1776's Avatar
Still haven't seen proof that the 1 7/8 is worthwhile overall for <500 RWHP -- sure seems you would suffer on the low end.
When I say proof, I really think the test would have to be with say ARH Headers & Y and the rest of the car unchanged except for say an SLP FlowPac and this same car dyno'd on both 1 3/4 & 1 7/8.
Originally Posted by The Alchemist
According to the link, he went from QTP 1 3/4 headers with a shitty ypipe to ARH 1 7/8 headers with a high quality ypipe. So I'm guessing that he gained from both of those changes.
Old May 21, 2011 | 08:29 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by silverz28camaro
I'd have to say it because of cost, and maily that people want a slip fit without welding, if you wanted to go bigger then 2 5/8...factory slip size to the catback, you would need to cut the old section off and re-weld, but it would be well worth it
Yeah, but even the merges on a lot of Y pipes look like garbage. You'd think they could at least put something nice on there.
Old May 22, 2011 | 08:20 AM
mike c.'s Avatar
I had a fab shop that does **** like that do one for my car. Mine looks good and is a lil larger,but your's looks even better.. Throw another pic when it's all done. You are running a catback too,right??
Old Jun 1, 2011 | 10:46 PM
chrs1313's Avatar
very nice, it will definitely pick up some power and tq...
Old Jun 1, 2011 | 11:38 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Looks like the y merge that lsxtremeperformance used to make. That's the one I had picked out if I didn't go true duals. I checked their site last night, and they're shut down
Just sucks b/c they actually made a really good Y pipe.
Old Jun 2, 2011 | 04:30 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Not to Hijack the thread but this has been done. It is proven that an 1 7/8 header will pick up power on a close to stock motor in the higher RPMs and match it in the lower.
Nice looking y-pipe, keep us posted if it picks up the power you were talking about!
Old Dec 5, 2011 | 07:39 PM
silverz28camaro's Avatar
I just wanted to add a pic of the flowmaster and magnaflow mufflers I'm running......
I'm finally going to the dyno Monday and the changes are..this exhaust, fast 102vs fast 92, and +4cc pistons...so compression is up .4 from 11.0 to 11.4
Last dyno run was 451 rwhp 380rwtq through an unlocked vig 3600 converter 4l60e 3.73 12 bolt
Old Dec 6, 2011 | 10:55 AM
disc0monkey's Avatar
bro that ***** gonna be rasp city
Old Dec 6, 2011 | 11:58 AM
dr_whigham's Avatar
The Scammer Hammer
Are you dumping it, as in the Flowmaster straight into the Magnaflow, or running it out the back?
Curious to see results.
Old Dec 6, 2011 | 01:55 PM
TruBloodTransAm's Avatar
I have the pacesetter ory and it really is junk. I need to get something like this too.
Old Dec 6, 2011 | 07:48 PM
  #32
So far no rasp, it sounds really deep...almost like an old school big block.
The setup is dumped right at the axle...from inside the car its not to loud at all, I can still listen to my radio and cruise at 70 no problem. But from the outside it juist seems like there is a big cubed motor under the hood pounding the ground.
There was more rasp with the factory catback setup.
Old Dec 6, 2011 | 08:29 PM
  #33
TImmy_Jones's Avatar
That looks IDENTICAL to the inside of my Hooker MaxFlow muffler.
All the power and half the sound....works great for roadtrips and when I have to get her inspected...otherwise too damn quiet.
Old Dec 7, 2011 | 08:48 AM
  #34
Sorry man I was being sarcastic. It's funny because it's the most used word on this forum. And to top that ppl rag on catbacks mostly slp for being "raspy" and to use a different catback to mask the problem instead of correcting it like you have done here.
Old Dec 7, 2011 | 12:57 PM
  #35
99 PROBLEMS's Avatar
can't wait for the end result!
Old Dec 7, 2011 | 01:16 PM
  #36
JRENIGAR's Avatar
Alright, stop being an a-hole and build me one already, j/k. Intrested in results as we are verry close in rwhp.
Old Dec 7, 2011 | 07:47 PM
  #37
Video with sound clip on the dyno to come Monday...in the upper rpms you can still tell its LS!!! My car revs and makes power to about 6,800, and my rev limiter is set to 7,200, so we will get a good sounds range throughout the rpms. I should also have a print out of my old dyno and this new one...
Old Dec 8, 2011 | 01:09 AM
  #38
99Bluz28's Avatar
If you need/want a shorter Y-merger consider a one from Vibrant Performance, they're a work of art!
http://vibrantperformance.com/catalo...e.php?pID=1681
Old Dec 8, 2011 | 06:41 PM
  #39
That one looks pretty good also, I think I want to do a setup like this for my truck also...The good merge seems to add some low end and midrange TQ..that will be good for my heavy truck with tall tires
Old Dec 12, 2011 | 07:12 PM
  #40
The Cam is holding me back for sure, but just like chrs1313 I picked up big tq and hp in the 4K-6.5K range
