My Ebay header install...
Old May 23, 2011 | 04:55 PM
TheSilverOne's Avatar
yes reusing stock LS1 MLS exhaust manifold gaskets is fine.
Old May 23, 2011 | 04:59 PM
slikrider20's Avatar
Smoke is gone. Whew
Old May 23, 2011 | 07:39 PM
s25hanh's Avatar
Why cant you use the gaskets that come with the headers?
Old May 23, 2011 | 08:21 PM
TankTheTurtle's Avatar
because they are made extremely cheap and will burn through and leak
Old May 25, 2011 | 12:50 PM
Originally Posted by LS1aiden
I have those exact same headers I wish i wouldve wrapped mine cuz they heat up like crazy! uh for the reservoir you can get that off GMpartsdirect.com pt#26068934. its about 60 dollars and for the egr, just delete the system, you need the block off plates. you can get them off ebay for like 5 dollars. egr is only for smog anyway.
Is there any bad that comes from them heating up? I started my car for all of 30 seconds and the header was already hot enough to burn my hand......are my spark plug wires in danger?
Also, i'm a little confused about the bottom bolt on the steering linkage. I got the linkage slipped over and all the way down over that joint ( i don't know what you call it) But that bottom bolt doesn't seem like it really does anything. It screws in but the side is completely open so it seems like it could just slip out.
