My Ebay header install...
Another issue i have is the AIR pipe things on the headers. The bolt holes are alot bigger than stock ones, the EGR one is the right size though. Anyone ran into this before? I wish i knew what size it was. I'll add pictures to this thread shortly.
As for the A.I.R. Fittings on the headers, you'll need to get a set of 4 bolts and nuts (I used lock washers as well) that fit the holes.
Good luck with the rest of the install.
I just got my Y pipe on and all the clamps tight, everything seems to fit perfectly.
My only problem now is i now broke my power steering pulley trying to get that damn thing off (don't ask how) I don't understand the pulley puller tool at all. I can't get the pulley off to save my life.
http://www.youtube.com/watch?v=xh4L1gjABQk
Also, which Y pipe did you use??
but ill be running an X w/ mine no Y
I "borrowed" the nuts, bolts, & washers that I used from the Shop at work. I'll check the pitch tomorrow and get back with you.
Never reuse gaskets like that.
If the car is smoking longer than that...then you may be in trouble, like a valve cover gasket, but you should be fine.
