Stupid Question....is there difference between driver/pass coil packs?
Old May 22, 2011 | 08:38 AM
So.jerZ-28's Avatar
Default Stupid Question....is there difference between driver/pass coil packs?
Not a noob.....but was curious if there is a difference between driver side / passenger side of coil packs? meaning can the driver side rack go on the passenger side?
I would think there is due to firing order/wiring. And if so, how do you determine which side is which?
Thanks in advance!!!
Old May 22, 2011 | 08:50 AM
Pocket's Avatar
They can be swapped directly. This comes in handy when tracking down the cause of a dead cyl, if the no fire follows the suspect coil, its bad. If not, its something else
Old May 22, 2011 | 05:40 PM
LS100CAMSS's Avatar
Swapping coils does not affect the fireing order. Just make sure all your harness connectors are in the propper location. The same is true for injectors. You can swap injectors to help diag misfires.
Old May 22, 2011 | 08:47 PM
MattSapp95_T/A's Avatar
I think he means can he take the complete coil setup (brackets and coils still connected to the harnesses) and swap them from one side to the other..
Old May 22, 2011 | 09:31 PM
So.jerZ-28's Avatar
[QUOTE=MattSapp95_T/A;14946303]I think he means can he take the complete coil setup (brackets and coils still connected to the harnesses) and swap them from one side to the other..[/QUOTE]
^ this !!!! yes or no?
Old May 22, 2011 | 09:39 PM
southsidecox's Avatar
assuming their all good i would say yes!
Old May 23, 2011 | 05:29 AM
Paul Bell's Avatar
That's MISTER MODERATOR
No, all the coils on an engine are identical. Yes, the coils assembled on their brackets work on either side.
