Poly Motor Mounts HELP!
Old May 26, 2011 | 12:08 PM
redbird555's Avatar
Default Poly Motor Mounts HELP!
Hey guys I have my whole k member out for an engine swap and I'm installing new poly motor mounts. I've got one side in but for the life of me I cant seem to get the other side to line up be it with a pry bar, jack, or cherry picker. Both motor mounts are correctly in the clamshell with the tabs facing up. This may sound like a dumb question but is there a right and left side motor mount clamshell? They look the same to me but who knows maybe I got one side mixed up with the other?
Old May 26, 2011 | 12:10 PM
Full-Force's Avatar
they are same
Old May 26, 2011 | 12:20 PM
redbird555's Avatar
thanks thats what I thought maybe the fact that theres no weight on the k member from the car has something to do with it. anyone have some pointers on getting them to line up
Old May 26, 2011 | 12:25 PM
01ssreda4's Avatar
Yeah, loosen the bolts back up. No reason to have them completely tight. This will give you some wiggle room.
Old May 26, 2011 | 12:38 PM
redbird555's Avatar
Thanks guys that's what I tried right before lunch I loosened up all the bolts on the block and the one bolt in the clam shell isn't even tight boils I loosen the 4 bolts that hold the clam shell together also?
Old May 26, 2011 | 12:57 PM
HVYMTL's Avatar
This, and maybe try loosening the bolts that hold the pedastals to the K member also. I didn't tighten anything until all bolts were started.
Old May 26, 2011 | 01:05 PM
01ssreda4's Avatar
Snap a picture of what you got....you can't get the long through-the-center bolts in?
Old May 26, 2011 | 01:07 PM
TS99V6's Avatar
no need to loosen the bolts that hold the clam shell together. All I loosened was the 4 bolts that hold the pedestal to the k-member. Worked like a charm
Old May 26, 2011 | 01:51 PM
MTBSully's Avatar
i didnt have any trouble with mine at all until the passengers side. Then i used the scissor jack between the firewall and the motor mount and got it to line up perfectly
Old May 26, 2011 | 01:55 PM
redbird555's Avatar
Here's what I've got and ya I cant get the center long bolt to line up no matter what I use I cant get it to push far enough over to get this bolt in.
PASS SIDE
DRIVERS SIDE
Thats what I'm thinking I'm going to try next I was trying to avoid it from fear that it may shift the engine around a little too much when trying to put it back in the car but I dont think it will be that bad and seems like the only option.
Old May 26, 2011 | 02:35 PM
Pocket's Avatar
Loosen up all the mount bolts on both sides, not just the 4 attached to the poly mount
Itd also help to jack the engine up some more
Old May 26, 2011 | 03:51 PM
TImmy_Jones's Avatar
^^This guy^^
Old May 26, 2011 | 04:03 PM
redbird555's Avatar
Your talking about the bolts connecting the pedestal to the k member correct?
Old May 26, 2011 | 04:53 PM
sjsingle1's Avatar
loosen ALL the bolts...or even remove them as you see fit.......K.......MM.....jack up engine higher.......hand tite bolts as they fit.........and you really only need 2 bolts to hold the clamshell together......thats what i did
Old May 26, 2011 | 05:56 PM
01ssreda4's Avatar
You're good, you don't need to loosen any bolts. All you need to do is pick up on the left side of the engine only since the right side bolt is already in. Pick the weight up some, and use a pry bar carefully if you have to and get the hole sorta lined up and force the head of the bolt in far enough that you can tap it with a hammer. Tap it till it comes out the back. Done that a million times.
Old May 26, 2011 | 06:49 PM
redbird555's Avatar
I had my dad come over and help and we still couldn't get anywhere with the prybar. Finally I gave in and loosened the pedstals up a little bit and shortly after I got enough room to get the bolt in. Thanks for all the help!
Old May 26, 2011 | 08:13 PM
WKF's Avatar
WKF
I feel for ya man........ two weeks ago I did mine while I was doing my LT's.
Now this last time was my 4rth time doing these helping various friends out so I had a pretty darn good idea of what needed to be done. Well for some reason my care was the pain in the ***. It took me probably 10 hr's & 3 separate times installing them & uninstalling them.
I was so pissed the last attempt....... I had ALL bolts lose still ... but this time I had my long bolts in & lose. I could only get one bolt in the drivers side pedestal because the alignment for the pedestal just was not there for my car.
I finally went with my original idea of a pitch bar to force things where they needed to be to get the last three bolts in (all pedestal bolts).
I had no pitch/pry bar here at the house...... & I was going to be damned if I didnt spend all day on it & not get it........
So I took all the weights off my curlbar in the garage & placed it through the middle of the drivers side pedestal & used it as a pry bar. It worked after a try or two.
If I had it all to do over again Id definitely want a friend around for help!
It would have been quite a bit easier.
Old May 26, 2011 | 09:21 PM
redbird555's Avatar
ya man I hear ya btw I'm gonna replace my front pump seal in the 4l60e before I put it back. It looks like theres some kind of clip that holds the seal in, I've never seen one setup like this does the clip just pop off and then you pull the seal out?
Old Jun 8, 2011 | 08:55 PM
ffrh911's Avatar
Solid motor mounts FTW
Old Jun 9, 2011 | 01:18 AM
pheer's Avatar
THIS and done!
i should probably do that myself!
