double check my header part list
Old Feb 25, 2004 | 01:35 AM
QCKZ28's Avatar
Default double check my header part list
im getting ready to install headers on a 02 t/a ws6 M6
help me make sure i order everything right:
JET-HOT longtubes for LS1 with emissions (02 has AIR only right?)
hooker y pipe p/n HOK-16723
02 sims
reuse the stock gm gaskets
reuse the stock header bolts
will the stock ones work on the jet hots?
is this every i need?
jesse
BTW this is my 1st post on here
Old Feb 25, 2004 | 04:36 AM
CRAGER's Avatar
Administrator
02 sims
jesse
Well first off, WELCOME!!!
"02 has AIR only right?" If you are asking about the EGR then yes you are right.
You might need extensions for your front o2's, and while the everything is off you might as well put some spark plugs and thicker wires in there. Everything else seems fine. Oh, and a very tall jack! lol
Peace,
Craig.
Old Feb 25, 2004 | 05:04 AM
JohnnyStorm's Avatar
I just put a set in but they were shorties, no clearance problems. You will probably have some clearance issues so a huge pry bar is your friend. Also get a 10mm gear wrench this also is your friend.
Old Feb 25, 2004 | 10:01 AM
FAST LS1's Avatar
Like others have said change spark plugs while your doing it to some NKG's, I personally wouldn't upgrade to larger wires though. Also having an assortment of good quality 10mm wrenchs and sockets will help.
Old Feb 25, 2004 | 10:06 AM
Steve98Z's Avatar
Beer and Band-aids
