LS6 Intake Vs Aftermarket
Old Jun 4, 2011 | 11:05 AM
  #41
lemons12's Avatar
Originally Posted by Fbodyjunkie06
Only in a boosted set-up would the TB be a restriction, or on a 400+C.I. motor. What is the stock LS6 TB...78mm? 80? I was thinking about getting my TB ported. What is the biggest TB you fit on a LS6 intake without a lot of extensive mods? I think I've seen 85mm on them without mods correct?
Stock is 78. If I remember correctly an 85 will bolt right up.
Personally, I would just get the stock one ported.
Old Jun 15, 2011 | 10:09 PM
  #42
muddyjimmy's Avatar
So where does the LS6 intake start to fall off rpm and lift wise on a stock cube LS1 with 243/799 heads? Is there any info on flow numbers for the LS6 topend?
Old Jun 15, 2011 | 11:35 PM
  #43
hitmanws6's Avatar
The LS6 falls off when you add anything really, for mild setups other intakes will shine above 5500 or so, more detailed setups you will start to see a lot of midrange gains
Old Jun 16, 2011 | 06:49 PM
  #44
muddyjimmy's Avatar
Down the road I may end up with a 4xx cid LSx, but for now I am just looking to add a little more to my nice weather DD. I have already purchased some 799 heads and LS6 intake to top my stock cube LS1. I am still researching cams, and I am looking for info on the general rpm operating range of the LS6 intake.
Old Jun 16, 2011 | 07:59 PM
  #45
Mike Morris's Avatar
I gained about 1.5 MPH and 2 tenths on a SI car with that LS6 intake/ported TB over a stock LS1. If you have lots of money to burn than do the Fast and TB now-you will see improvement even on a stock car but as mentioned there are better mods even when cammed. I am really curious how much I might have gained had I used a TPIS modded LS6 intake and NW TB I missed out on instead.
Old Jun 18, 2011 | 04:33 PM
  #46
libertyforall1776's Avatar
Question
Have before/after dyno results?
Also, what does S.I. stand for?
Originally Posted by ULTIMATEORANGESS
its up to you if its worth it. i had an ls6. then a fast 90 now a FAST 102.
Old Jun 18, 2011 | 05:04 PM
  #47
ULTIMATEORANGESS's Avatar
Smile
stock internals.
Old Jun 18, 2011 | 10:49 PM
  #48
R6cowboy's Avatar
Originally Posted by ramairetransam
does porting the ls6 help at all>?
Does anyone have results from a stock LS6 intake and TB compared to a ported LS6 intake and TB?
I was informed by a vendor their ported LS6 intakes are tested and flow around 14cfm over the stock LS6 intake (I'll have to go back and look up a past email to be certain of the exact numbers). But if that is true, that has to be a decent hp gain, especially on a H/C motor.
But anyways, the FAST intake is a superior design to the LS6. They're both great pieces.
Old Jun 18, 2011 | 11:16 PM
  #49
lemons12's Avatar
Instead of porting why not pick up a used 90 or 92 setup? 350$ selling your stock stuff+money from porting would almost pay for a complete 90/90 or 92/92 setup if you were patient. Wouldn't make sense to me.
Old Jun 18, 2011 | 11:40 PM
  #50
meine96ws6's Avatar
I agree...I would be patient and buy the fast set up and throttle body and just sell my current ls6 set up.
Old Jun 18, 2011 | 11:52 PM
  #51
Bingo
Old Jun 19, 2011 | 12:12 PM
  #52
R6cowboy's Avatar
Good point, but the money spent on a ported LS6 set-up is still worth the cost. My experience, I'll have $600 total into my ported & polished LS6 intake and throttle body set-up. That's including purchase of the LS6 intake. For what I see a used FAST 90 or 92 set-up will run $1000-$1200, right?
I was told the ported LS6 set-up flows almost on par with a FAST 78. That comes from a vendor that tests and sells FAST intakes as well. The ported LS6 runners flow 12.5cfm @.600 over the stock LS6 runners. That is a pretty good gain, bang-for-the-buck if you will, for only $200. And the stock TB opening is ported to 78mm over the stock 75mm.
Point being, the cost of either set-up is worth it. For a little more money you'll get a little more power (w/ FAST). Pretty much you get what you pay for.
Old Jun 19, 2011 | 12:28 PM
  #53
R6cowboy's Avatar
I think the FAST intakes are worth it. But the reason I went with the LS6 intake is because I want to keep under the hood looking as stock as possible. Otherwise I would've gone with a FAST.
  #54
lemons12's Avatar
I sold my ported 102 setup with rails for 1100. You can get a 90/90 setup for 700-800.
Old Jun 20, 2011 | 12:18 PM
  #55
Cosmos's Avatar
If your lucky. A lot of people think they are worth more than a new one. Ive seen them go for 1100! You can get 102s for 800 new!
Old Jun 20, 2011 | 01:44 PM
  #56
BirdsSince16's Avatar
Shave the letters and paint the FAST black?
Old Jun 20, 2011 | 10:00 PM
  #57
20SOM01's Avatar
What kind of HP gains did you receive after the port & polish?
Old Jun 21, 2011 | 01:02 PM
  #58
maxx880's Avatar
I went with a ported FAST 90/90 setup on my bolt-ons car and picked up 29hp/33tq over a LS1 intake. Go with a fast and dont waste your money on anything else. bolt ons with fast 90 i put down 378hp/393tq on a dynojet i have dynosheets posted in my online albums
Old Jun 21, 2011 | 01:58 PM
  #59
juniorz28's Avatar
LS6 for now.. Save your cash for a Tony Mamo ported FAST manifold.
Old Jun 21, 2011 | 02:21 PM
  #60
MikeWS6's Avatar
Yeah well something was up with that dyno unless you are considering a cam, a bolt on
