BBK SSI Intake, Potential Vacuum Leak....
I have been tracking down a vacuum for a couple of weeks. I bought the car it had the BBK SSI and 80mm TB on it. I found a few glaring issues I fixed and am trying not to pull the intake off.
I removed the cover plate on the egr hole (which I don;t have, '02) and found the oring that should seal the plate to the intake does not fit right (see photo).
![](http://i112.photobucket.com/albums/n168/93vn750/P1030307.jpg)
Do you think that this could be a potential vacuum leak source? The groove is ~ 0.170 deep and the oring is 0.130 thick.
If anyone has a BBK SSI and no egr, could you pop the plate off and see if the oring makes a good seal?
Thanks.
Jon
Thanks.
Jon
