Header Gasket Question
Old Feb 25, 2004 | 05:34 PM
nbmls1ta's Avatar
Default Header Gasket Question
I bought a set of Pacesetter headers from a member and was wondering if I can use stock gaskets with these headers? Do I have to get the gaskets from Pacesetter or will any header gasket for an LS1 work? Thanks for the help.
Matt
Old Feb 25, 2004 | 05:38 PM
Trans_AmGuy's Avatar
Your stockers will work fine.... I'm still using the same ones from my Mac headers and now Jet Hots.
Old Feb 25, 2004 | 06:00 PM
nbmls1ta's Avatar
Thanks for the help. Are the ones you are using your stock ones or are they the ones that cam with the Macs? Is there a difference?
Thanks again
Matt
Old Feb 25, 2004 | 06:05 PM
There wont be any difference but I'm still using the stock metal ones. The others have a tendancy to tear if you're not careful when you try to start some of the header bolts. BTW you can reuse your stock header bolts as well if they are still in good shape.
Old Feb 25, 2004 | 08:48 PM
WILWAXU's Avatar
IMO, use the stock ones or GM replacements. They kick azz!
Old Feb 25, 2004 | 09:29 PM
nbmls1ta's Avatar
Ok, that makes me feel alot better. I was afraid I was going to have to order special gaskets. I am happy now. Thanks guys!!!
Matt
Old Feb 25, 2004 | 09:59 PM
Z28Venom's Avatar
Matt
I'm about to install my Pacesetters also. When you say use the stock gaskets, does it mean that I can reuse the ones that are on the car with the stock manifolds right now. Or do I need to go to GM and order the same part number.
Thanks
Old Feb 25, 2004 | 10:02 PM
Thanks
You can reuse the ones you have on right now.
 Michael S. Palmer
Old Feb 26, 2004 | 12:13 AM
Tranzor's Avatar
IMO, I'd get some new metal GM gaskets... I had a friend of mine from these boards recommend getting some new ones, and when we pulled my exhaust manifolds and saw the gaskets, I'm glad I did. Sure they were re-useable, but they weren't in the best of shape. And my car only has 18600 miles on it.
Old Feb 26, 2004 | 05:58 AM
JohnnyStorm's Avatar
You should see them at 29,000 miles. Get new stock gaskets for $13.00 each and you will have some peace of mind and no exhaust leaks.
Old Feb 26, 2004 | 11:01 PM
WILWAXU's Avatar
I have and have seen others reused GM gaskets without issue, but for the cost and possible headaches I'd pickup a new set.
Old Feb 26, 2004 | 11:23 PM
black_z's Avatar
I would buy new too. I did.
