throttle body hitting water pump??
Old 06-20-2011 | 10:07 PM
2001slpcamaro's Avatar
Default throttle body hitting water pump??
i got a 102 nick williams throttle body and its hitting my water pump on the drivers side. any suggestions?
Old 06-20-2011 | 10:59 PM
rigid's Avatar
I hand to grind my waterpump. After it gets hot it still touches. I think that's just how it is with a stock LS1 pump.
Old 06-21-2011 | 05:05 PM
SunsetOrangeZ's Avatar
Same here, had to hit it a little with a disc grinder. Just take off the minimum, and you wont mess anything up.
You know, grind; check fitment- grind a little more; check fitment, etc.
Old 06-23-2011 | 07:17 PM
thanks guys. it worked
Quick Reply: throttle body hitting water pump??
