Alternator....
Old Jun 28, 2011 | 08:43 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
First thread started out badass, then photobucket fail.....
Second one was good. I think that's a pretty good mod that often times get's neglected.
sjsingle1, appreciate you running down those threads.
I've been enlightened
Old Jun 29, 2011 | 11:30 PM
sjsingle1's Avatar
Default Alternator ****....Pt 2
finally got that monster alt in the car today.....was a little different than the other AD244 I had in there.......the stator was a little wider causing a little interference with the power steering return line......i had to tweak the line toward the ground to fit......i found out there are 2 different size pulleys and i must have got the larger of the 2......the belt is a little to tight for my tastes and i will get a longer 1 tomorrow......i switched out the 150 amp fuse for a 200 amp fuse.......the wire for the computer was a little tight......good thing thing i made it long for the other AD244.......i dont know what it is.....but the car now seems to love having the extra amps.... for the computer.......coils.......a/c...lights.....the dummy gauge stays at a rock solid 13.5 volts......its a must have in my book.......GET 1 TODAY
Old Jun 29, 2011 | 11:31 PM
sjsingle1's Avatar
sjsingle1's Avatar
had to pull the whole bracket out
Old Jun 29, 2011 | 11:32 PM
sjsingle1's Avatar
look ma.......no alt
sjsingle1's Avatar
sure is purdy
sjsingle1's Avatar
sjsingle1's Avatar
Old Jun 29, 2011 | 11:33 PM
sjsingle1's Avatar
Old Jun 29, 2011 | 11:36 PM
sjsingle1's Avatar
wires for the BIG 3......welding wire i got from tractor supply......dont know the gauge.....but it was the biggest they had
Old Jun 29, 2011 | 11:37 PM
sjsingle1's Avatar
  #32
sjsingle1's Avatar
  #33
sjsingle1's Avatar
the new alt has a 200 amp fuse
  #34
sjsingle1's Avatar
Old Jun 29, 2011 | 11:38 PM
  #35
sjsingle1's Avatar
Old Jun 29, 2011 | 11:40 PM
  #36
sjsingle1's Avatar
https://ls1tech.com/forums/generatio...rn-pt-2-a.html
check out the conclusion
Old Jun 29, 2011 | 11:41 PM
  #37
sjsingle1's Avatar
https://ls1tech.com/forums/generatio...ator-****.html
check out part 1 for underhood pics of the alt
Old Jun 29, 2011 | 11:55 PM
  #38
Snake_Skinner's Avatar
OP could you plz PM me link also, I will be doing the big 3 plus this alternator once my stereo build goes under way. Thx in advance and thx for sharing.
Old Jun 30, 2011 | 01:26 AM
  #39
01ssreda4's Avatar
I merged the threads. There is no need for two. I'm seriously considering changing the thread title as well.....
Old Jun 30, 2011 | 09:02 AM
  #40
dr_whigham's Avatar
The Scammer Hammer
Definately on my to do list now. sjsingle1, thanks for the rest of the pics. We have plenty of welding shops around here, so I think that's the route I'll be taking.
