Engine temp gauge not working on 98
OK, thought maybe it was a simple mismatch issue. Black is sensor ground. Yellow is sig. So, green is the gauge wire. Maybe the gauge wire is loose in the connector? Is there a CEL?
Take a spare piece of wire & touch one end to the block & the other end on a metal part of the sensor. Does gauge wake up when you do this? If so, it's a ground problem. Only use sealer on the threads nearest the nut part of the sensor so that the threads below can make contact w/ the head.
At the PCM, the yellow wire needs a ground, as well. The ECT (yellow wire's PCM ground) ground is a brown wire located @ pin #25 (blue side) on PCM. This ground could be bad. Way to check it is to use a 5v ref from pin #65, grey wire (blue side). Connect a multi-meter from #65 & #25. It should read 5v. Key must be on, engine not running.
Could also be as simple as a bad temp switch. Although, there should be a CEL related to ECT. Once you figure it out, change the oil, 'cuz ECT problems cause the engine to run rich.
Have you tried disconnecting the battery for a while? I know that sounds like a weird fix, but my gauge went dead once after I had the battery disconnected, then started working again when I disconnected and re-connected it.
That's all that can be done w/ electrical issues. Eliminate one thing @ a time until the issue is found.
