what is needed for 2001 LS1 Fbody to crank without PCM..
Old Jul 18, 2011 | 04:47 PM
soundengineer's Avatar
Default what is needed for 2001 LS1 Fbody to crank without PCM..
Putting in a Holley EFI system... cant get the car to crank over...
I have only removed the Stock PCM and engine(blue/red) harness... everything else is in tact.
Turn the Key... get nothing.
I can bump over the starter by jumping 12v from the battery and it will start and run...
Just no starter from the Key..
what am I missing, or what do I need to add or jumper to make it crank the starter.
Thanks to anybody who can help.....
I'll but you an internet beer..LOL
Old Jul 19, 2011 | 01:21 PM
2000PewterT/A's Avatar
Does your car have the VATS system"vehicle anti theft system"? If so that might what is causing your problem.
Old Jul 19, 2011 | 02:18 PM
its not Vats....
I ended up solving it last night...
Needed a ground in the relay....
for whatever reason.. I had no ground happening... I added one and its all good...
had the wire... Just no actual ground connection from that wire...no idea why at this moment... I just ran a new one...
problem solved.
