Can I remove the AIT pump and not set off the SES?
You might as well pull the pump if you are disconnecting it, that way you won't have to listen to it on cold start ups, and you will be eliminating the weight as well.
Search the site, I have read a couple of detailed write ups on here on AIR pump removal.
I have not done it myself yet, my car is still a mod virgin.
From removal of the AIR only. You SHOULDn't set any codes.
David
