Which 02 sensors to buy?
Old Jul 29, 2011 | 11:02 AM
km346's Avatar
Originally Posted by LS6427
See, some PCM's will not except Bosch................ All PCM's are NOT the same in our F-Bodys. Some do their own thing.
Yeah GM made the anti-Bosch PCM's that do their own thing....
Ive never had a car that "just wont run" on a Bosch brand 02 sensor, and trust me Ive installed my fair share of 02's.
Just cause i have them sitting next to me, here is a pic of how long my 13111's are...
total length is just over 51 inches.
Old Jul 29, 2011 | 11:52 AM
LS6427's Avatar
Well I'll put it to you as simple as I can because this subject has been beat to death. You haven't been around here long enough to read how many problems people have with Bosch **** sensors over the years. MY car won't run on Bosch 02 sensors, as I already said, and I have friends here in town who's cars WILL NOT RUN on Bosch 02 sensors, as well as people all across this country. Also, if you think all of our PCM's operate exactly the same, you're plain ignorant to how these PCM's work.
The first time I had an 02 sensor fail I stopped by Advance Auto and picked up a Bosch 13111 and went to Mecedo Motorsports so they can put it in. On start-up the engine would hardly run. They told me to go to the local dealer up the street and get a GM 02 sensor....they let me borrow a car and I went and spent way over $100 for one sensor. Came back, put it in and the engine was perfect.
So don't tell me that Bosch sensors work in everyones car.....you will sound like an idiot because because of what I just told you about my car (PCM).
And a little NEWS FLASH for you.....GM doesn't design parts (their PCM) hoping that a company like Bosch will THEN later on make an 02 sensor that will work. Its the aftermarket companies like Bosch that have to design their parts to be compatible with the GM PCM.......the other way around in how your brain thinks.
Tons of aftermarket parts that companies make are crap and don't work as good as others. Wake up.......Bosch 02 sensors are one of those parts.
Period.
Old Jul 29, 2011 | 11:54 AM
LS6427's Avatar
Originally Posted by 01ssreda4
I and just about everybody I know runs the 13111 and none of use had any problems. Perhaps you got a bad sensor but instead of finding a working replacement you decide to bash Bosch for the rest of your life. That's childish and irresponsible IMO.
Once again, there are people who have had problems with Bosch sensors for years. Which by your thinking means Bosch makes allot of "bad" sensors.....either way, why pay more for a Bosch sensor when the Denso is a far superior sensor and for LESS MONEY.
And I'm not bashing them, they suck. They have to take it on the chin for making junk.
Old Jul 29, 2011 | 11:55 AM
HAZ-Matt's Avatar
I haven't used the Bosch O2s in the Formula, but have used them in plenty of other cars. The PCM thing is somewhat silly. There are different PCMs with slightly different OS's and mild differences in tunes over the years. There really isn't anything to affect O2 sensor reading. However, there is variance in mods that people perform, specifically LT's with different geometry and other things that manipulate exhaust temperature and velocity (cams, displacement, whatever...). I'm sure that any of them work well in OEM manifolds for which they are designed.
My Formula (with LT's) has had the OEM O2's (which were most likely "AC Delco" probably made by Delphi), Delphi replacements, and now Denso replacements. The Denso's have been the most finicky about switching at idle. They just don't work as well as the Delphi's did with my setup. Specifically, they set insufficient switching codes after the first diagnostic cycle after install. They switched off idle well, so I did some tuning trickery and got around it, but I wouldn't rate them as the best O2's ever.
AC Delco probably switched suppliers because Denso just gave them a better deal. And it wasn't like Delphi was part of the GM empire any longer. All in all the next time I replace mine I might try the NTK or Bosch. Or I might just go back to Delphi.
Old Jul 29, 2011 | 11:59 AM
LS6427's Avatar
Originally Posted by blackbird0230
I'm just really confused now. Can anyone clear this up for me? so I buy bosch 13111's I'll have a crap load of wire to zip tie right? And if I buy these denso's which are supposedly super awesome for less which part number do I order for my FBODY ta with LT headers? I dont recall if it was ever made clear whether he ran these with his Fbody or a corvette. I need to order some o2 sensors ASAP so the sooner the better
Dude, Denso 02 sensors have been the sensors that have been going into Vettes for years and years. GM now uses them for their own sensors.........if Bosch sensors were better than GM would have chosen those sensors to put into their AC Delco boxes at the dealerships and sell them for upwards of $180 each.
I really don't understand why people are having issues with wire length....look at my pictures above that I took yesterday of my Denso 02 sensors. They are 10" long and 14" long. And the 14" long passenger side needed to be folded and zip-tied to the tranny lines because they were too long.
So my best advice.....put the car up on ramps or a lift.....measure what you need for wire length for whatever positions you are using.
THEN........order the Densos for $33.00 each if you can. If not....good luck with Bosch.
Thats all I can say I guess...................I use Densos, wire length for my LT headers is fine and they are the best sensors, by far, on the market.
Old Jul 29, 2011 | 12:04 PM
LS6427's Avatar
You're wrong.
My original factory PCM from 1998 was wacked. I didn't get codes for failed MAF, TPS, or IAC valves. My friends 98-02 F-body's all do. And some other people don't get them that I've talked to also.
I didn't get a code for a failing Crank Shaft position sensor until its totally failed. I know people who get the code and SES light as soon as it starts to act up but is not yet failed.
My PCM now is a new one so I haven't had any problems yet, so I have no idea how this PCM will act or warn me of problems.
Oh....my old PCM totally took my MAF out of the loop and turned it off. Every tuner on here and builders said thats impossible......until I had a guy hook it up to his tuning software and said....."huh, your right, your MAF is OFF." Its simple, there's still allot people don't know about these PCM's, including the men who designed it at GM, and people will continue to figure them out for years.
Old Jul 29, 2011 | 12:45 PM
HAZ-Matt's Avatar
You're wrong.
About this, I doubt it. There is a difference between claiming that there are real differences in the operation of an original functioning PCM and one that may have been damaged.
There isn't any magic that is going on inside them. These aren't biological creatures prone to irrational behavior. What are the real differences in hardware and software that you are talking about?
I know you are providing anecdotes about a single 98 PCM that you have since replaced as faulty... that doesn't prove much about the state of PCMs as a whole. Certainly a broken PCM isn't going to function as expected. But how does that prove that you know more about their PCMs than the GM engineers? I don't even know that you had a stock GM tune in that computer. It would have been interesting to see a scan of the PCM.
Additionally, even though fault detection wasn't to your satisfaction in the software version, can you provide some data about changes or updates relating specifically to the O2 sensors? The OEM replacement sensors from whoever are built to conform to nearly the same specifications. It would be interesting to see A) how certain 98 PCM software / hardware specs could tell it was connected to a Bosch sensor, and B) what engine management error it then caused to prevent your car from running. Then perhaps we can see why there have been so many other cars on this board that have run the Bosch sensors without anywhere near as drastic problems if any.
You chastised a posted above for not being on this board a long time. Well if board membership length means anything I have been on here for a while. It wasn't an accident that the Bosch sensors appeared all over the place. They were probably the most used and recommended sensors for LT's. Some of the things people claimed about them are likely untrue (specifically stronger heating elements for the Corvette Rear application), but in general they probably worked as well as any other OEM type replacement. None of them work as well as they do in stock manifolds though, and if you also throw a crappy tune on top of it they aren't going to perform to expectation.
The real issue is that people are using parts designed for specific parameters and using them in an environment that does not meet those parameters, which by and large is the result of relocation by LTs, cam specs, and even poor tuning. You also do not hear about how many people use them without issue. People don't make posts like "Hey my O2s are working, just wanted to let you know." On the internet, problems travel at the speed of light, but success is reported by pony express.
Old Jul 29, 2011 | 12:53 PM
LS6427's Avatar
I've always said that some people have absolutely "no issues" with Bosch sensors. Why chance it when there are Densos that have none of the issues, ever. Makes no sense. Thats all.
And I had failed sensors (TPS, IAC, Crank sensor) when my car was bone stock 1-3 years after I bought it. My PCM failed on me when my PCM-to-ground wire came loose about 1 1/2 years ago. So my original PCM was fine for 11 years. It just DID NOT act like other 98 PCM's when it came time to throw a code.
Old Jul 29, 2011 | 12:56 PM
LS6427's Avatar
BOTTOM LINE everyone.........
Buy Denso 02 sensors if the wire length will work out. Cheaper, better and they have no issues like Bosch sensors do. Why risk it.
See ya.
Old Jul 29, 2011 | 12:57 PM
01ssreda4's Avatar
You said your piece, stop turning this thread into a huge disorganized pissing match.
Old Jul 29, 2011 | 01:27 PM
km346's Avatar
Period.
That's a great story... But you clearly don't understand how an 02 sensor works if you believe what your typing.
and
I really dont want to argue... Im not trying to say Bosch is the better sensor, because for longevity i do believe the Denso's are superior. Just read what you type before you post it man god.
Old Jul 29, 2011 | 01:34 PM
  #32
85CamaroZ28's Avatar
2344087 (11.81" long wire) and 2344025 (16" long wire)...are the only two Denso choices for 98-02 F-Bodys.....they fit all positions. Just buy the 2344025 for whatever position you need, the wire will be sure to fit all 4 positions. Zip tie the extra length. I've been doing that for years.
Doesn't matter though......its up to you to get the right wire length........thats why the part numbers are different. Just order the proper Denso.
Amazon.com has Part #2344617 Densos too, right now in stock. $53.00....44 inch long wire.
NEWS FLASH.......BUT THAT PART NUMBER.......DOES NOT FIT OUR F-BODY's......
No kidding it doesn't fit our F-bodys. I have no idea how he got the o2 sensors for a 98-02 F body to work with LT's. Our cars didn't come with LT's. Why do you think every vendor here sells EXTENSIONS when you buy Lt's from them. Like i said, I bought the 16" sensors thinking they were right for LT's. Got under the car and they were about a foot too short. I went to the parts store and I told the guy I had a 2000 vette and needed a rear o2. They pulled up the Bosch 13111 and I bought them because they were the only one's they had in stock. I gave you the part number for the densos as well.
Not trying to be a dick I just don't want this guy to go through what I did and get LT's and try a STOCK length wire only to realize its too short.
Old Jul 29, 2011 | 02:38 PM
  #33
LS1121's Avatar
I don't know why I continue to read this.......just stupid i guess lol
Old Jul 29, 2011 | 02:58 PM
  #34
HAZ-Matt's Avatar
This is the easy way to do it. Just as for a C5 rear sensor since it has the same connector as an Fbody but the long wire. A bunch of brands make replacement rear sensors for C5s. But Bosch is the most commonly stocked at the local chain stores it seems. Might have to order the Denso sensors if that is what you want.
There probably isn't a huge difference in most of these sensor brands. None of them have been flawless.
Old Jul 29, 2011 | 03:52 PM
  #35
Bramlok's Avatar
Hmm, just saw this thread.
I replaced both my o2's with densos. The left side denso failed at 3 months. The right side denso failed at 10 months. Both were replaced with bosch 13111 and have been working fine for 1 1/2 years now.
Old Aug 2, 2011 | 04:39 AM
  #36
jblack245's Avatar
Lol. I guess sum ls1 like denso some like Bosch. My ls1 don't like the Bosch. They only last about a year then foul all my plugs. Went thru 3 sets over 3yrs. Tried denso and ain't had a problem since. 2.5 year on these denso I got in now. Just my past experience with both brands
Old Aug 2, 2011 | 09:34 AM
  #37
LS1121's Avatar
Just because GM sell something doesn't mean it's "The Best" it means they like most big companies buy in quantities under contract, and they will buy what meets their Standards and usually they buy what is the Cheapest and will work and have a warranty.
So by what I am reading here is that some people believe that GM always has the Best Parts? lol lol lol ha ha ha
Old Aug 2, 2011 | 11:49 AM
  #38
blackbird0230's Avatar
Well I think it's silly to get this wound up about o2 sensors so I went with Bosch since I honestly wanted to separate myself from this argument, the wires are long but nothing some zip ties can't handle but I do have to say, my stock o2's must have been **** cuz when I plugged in the bosch's my idle problem fixed and it felt like I threw in a set of headers, it 'feels' like I gained quite a bit of power.
Now as far as life of them I will have to find out because I just got them yesterday
Old Sep 12, 2013 | 03:46 PM
  #39
LS6427's Avatar
Gotta bring up this old thread.......TO PROVE A POINT......about Bosch 02 sensors NOT working for some PCM's.
Haz-Mat, 01ssreda4 and km346:
I just had my brand new 390ci installed. The shop that installed my new engine had to replace one of my old 02 sensors because it was damaged. They bought a BRAND NEW Bosch 02 sensor 13111. It's been running rich on that bank, throwing a slow response code and also some other code about a circuit issue or some **** like that. The 5 year old Denso that they reused for the other side......its been working perfectly.
I tried to tell them Bosch sensors don't work with my PCM. They cleared the code a few times and it keeps coming back, yet I'm running rich also, which means there's a problem with the sensor.
I've been driving it but finally today put a new Denso 2344025 in. It instantly ran better and the codes are gone. No smell of fuel anymore either.
So all PCM's do NOT operate the same. Maybe I shouldn't say Bosch sensors are junk....because they do work in other cars just fine. But it's true they are junk for some cars. Therefore, it only makes sense to just buy the CHEAPER Denso sensors that work in all cars.
Old Sep 15, 2013 | 10:52 AM
  #40
sjsingle1's Avatar
when i installed my LT.............put in NEW bosch o2s......ran like crap and got LOUSY gas mileage......after 2 yrs put in NEW densos.......its a BRAND new car ....mileage went up 4 mpg....my .02
