How do you install your LT headers?
Old Jul 30, 2011 | 11:17 PM
Carlisle's Avatar
Default How do you install your LT headers?
From the top or bottom or both? I got TSP 1 7/8s going in being a PITA. Help please.
C.
Old Jul 30, 2011 | 11:22 PM
mjs1012's Avatar
I haven't personally done headers yet but i know that you need to jack the car up as high as u can and they go in from the bottom
Old Jul 30, 2011 | 11:50 PM
Carlisle's Avatar
I have a lift
Old Jul 30, 2011 | 11:54 PM
babbage1109's Avatar
It's from the bottom. You may need to remove the steering knuckle. I know I always do. Makes it easier and takes 5 minutes extra.
Old Jul 30, 2011 | 11:57 PM
z99ls1's Avatar
Restricted User
Yes both slide in from the bottom. Mine went in like butter. You have to take the steering knuckle off to get them on. Atleast I did. It will be a cake walk with a lift though. Btw you will need a partner to hold the header up while you bolt them in.
LT1559's Avatar
I would do both from the bottom i found it easiest that way...I'm dreading the day i have to install my longtubes again...
Old Jul 30, 2011 | 11:59 PM
In an ls1 car is not bad. I can't imagine an lt1 lol. I have mine on the garage floor right now. Doing motor mounts and all that.
Old Jul 31, 2011 | 12:01 AM
z99ls1's Avatar
Restricted User
Lt1 is a little harder to do. I have done them on both and ls1 is easier, but lt1 isn't way way to bad.
Old Jul 31, 2011 | 12:47 AM
sjsingle1's Avatar
did you read the stickees? LT only go in from bottom......i could not get the divers side in til i removed the motor mount pedestal
Old Jul 31, 2011 | 12:53 AM
Carlisle's Avatar
What about the starter?
Old Jul 31, 2011 | 12:57 AM
Leave it in place. Literally. Undo the plug wires. Take out spark plugs. Remove steering knuckle drop old manifolds and cats. Put new lts in.pretty easy to handle. You may want to take the pass side coil bracket off for more room to work in.
Old Jul 31, 2011 | 01:18 AM
z99ls1's Avatar
Restricted User
Once you get into it you will see it just takes a little work. Not rocket science or anything lol
Old Jul 31, 2011 | 01:30 AM
Carlisle's Avatar
Thanks for the help guys. I got everything off and changed my plugs, well, upon putting the driver side in I broke a spark plug, that's where I stopped for the evening. Hopefully O'reily's or Auto Zone has tr55's. I'm going to take the rest out, not sure what I was thinking, it was just sooo easy changing them with the manifolds off I couldn't resist.
C.
Old Jul 31, 2011 | 02:24 AM
z99ls1's Avatar
Restricted User
Yea you should've taken them out lol
Old Jul 31, 2011 | 06:19 AM
Advance auto parts has ngk brand plugs that's where I got mine
Old Jul 31, 2011 | 08:33 AM
mjs1012's Avatar
Autozone has them just tell them the part number
Old Jul 31, 2011 | 07:04 PM
Carlisle's Avatar
They're in. Finished up this afternoon. Neither the steering knuckle, nor the starter had to be removed. Only thing besides the manifolds/exhaust that was removed was the dip stick. Driver side went in pretty easy, took a little umpf to put it pass the oil drain bolt, that's all it really got hung up on. The passenger side took 20 seconds to get in position, even with the spark plugs still in it had plenty of room. Only real snag I had was the farthest back driver side header bolt hole got partially cross-threaded, I had to re-tap the hole, which, needless to say, was a huge PITA.
All in all I HIGHLY recommend the TSP 1 7/8" LT Headers, Anyone want me to post pics?
C.
Old Jul 31, 2011 | 07:34 PM
newchevyman's Avatar
I want to see them. I'm looking at picking these headers up in the next month or so. Dreading the install, I know it's doable just going to suck
Old Jul 31, 2011 | 08:21 PM
Carlisle's Avatar
That last one wasn't taken correctly cause I was in a huge hurry to get off the burning pavement haha, it's got about 4in of clearance. They were taken with a phone, sorry if it's somewhat poor quality/lighting. I'll have more we the exhaust goes on tomorrow.
C.
Old Jul 31, 2011 | 09:36 PM
Looks good glad you got it all sorted out. The clearances must be different for tsp headers than pacesetters I had to remove the knuckle but yeah. Have fun with it!
