SLP Air Lid: Before and After
Old Aug 6, 2011 | 12:37 AM
Paul Bell's Avatar
That's MISTER MODERATOR
01ssreda4:
Old Aug 6, 2011 | 12:44 AM
idle's Avatar
Originally Posted by Paul Bell
OK, you cleaned the clogged MAF screen and re-installed it. GOOD, leave it in.
SEARCH is your friend. SEARCH for all all the mods you're thinking of doing and learn the pros/cons of them. Doing mods without this free education then showing it off here will get you spanked a bit-as seen in this thread.
And don't be suckered into manufacturers claims, they're often hyped up.
Since you (OP) didn't interpret this right... No one cares about your MAF screen and don't touch it. Search if you have questions (and you need to based on your opinion that the engine makes 320 at the crank). If you have a modification, then I bet it's already been done... twice. Lastly, don't buy silly parts with 2 HP claims... probably doesn't work. Search on here first before you buy...
Old Aug 6, 2011 | 12:58 AM
01ssreda4's Avatar
You're right. This thread should be locked. But only after I restored it after OP deleted it and I set the record straight....
