SLP Air Lid: Before and After
Anyways, we get the thing on, I go to start it up and take it for a test drive. Right upon start up it starts idling really low, around 300-400RPM, sounds like it's going to die, so I rev it up a little to 2,000-3,000, it starts idling really low again, I give it more gas and then put it in gear. Not sure why it was trying to die, made me very nervous at first. So I took it out on the road, and even with the added weight of a passenger I am sure the car felt like it had more pull on the top end. A slight increase in throttle response.
Well my two of my friends wanted to drive it, so I let them, and I have to say, riding in the passenger seat of your own car feels very weird. Also, the car feels a lot faster when you're riding in it and not driving it. I guess because you don't know what to expect, when you are driving you brace yourself for when it throws you back in your seat.
So with the SLP LM1 Cat-back and the SLP Air Lid, I have not dynoed it yet, but I'm hoping for it to be right around 325 crank HP now, compared to the 310 at stock. Also hoping for this air lid and cleaned out screen to improve my fuel economy. So far not regretting the install, didn't feel a real big improvement, but I'm sure it's there and every little bit helps.
The place most of the dirt gets past the filter is along the rear edge, with aftermarket lids. Best way I found to check for gaps was to turn on a flashlight, stick it on top of the filter, and put the lid on; light shining out makes for a pretty obvious hole. Some exterior weatherstripping typically fixes it pretty handily.
So 500RPM idle isn't too low? Good, I like low idles. I think having 2.73 gears probably helps with that.
You think your T/A is slow? Why?
-Idle speed will vary on engine conditions.
-RWHP for properly running stock LS1 cars is about 300 HP. It's difficult to estimate or calculate the exact crank HP without pulling the engine and dynoing it.
-The stock air box is not much of a restriction on a stock car. Other things come into play. Reality is your car is probably making the same power. Air intakes that take advantage of ram air effect while in motion do make more.
-The stock MAF is good to about 450 HP. De-screening it will cause turbulence causing the airflow to not hit the sensor at certain engine speeds and will probably cause drivability issues.
-A cat-back exhaust also doesn't do much as the real restrictions in the exhaust is the exhaust manifolds, cats and the y-pipe.
-Corvettes are faster because they are lighter and usually (from the factory) geared better.
SEARCH is your friend. SEARCH for all all the mods you're thinking of doing and learn the pros/cons of them. Doing mods without this free education then showing it off here will get you spanked a bit-as seen in this thread.
And don't be suckered into manufacturers claims, they're often hyped up.
And for the record, stock auto idle is 600 in P/N and 550 in gear. And your factory tach is not accurate to tell the difference in 50 rpms, it simply isn't that sensitive.
