pacesetter y-pipe opinions
Edit: Disregard, found this: https://ls1tech.com/forums/generatio...otsa-pics.html
The cheapest headers I would use would be Pacesetters. I've had a lot of good luck with them.
Do not use the Pacesetter Y-pipe. It is garbage. The "merge" is a tiny hole cut inside one of the pipes. Probably only a 2" hole and makes the pipe raspy. I've installed several Pacesetter y-pipes and they are all like this. I have no experience with the TSP pipe.
My recommendation would be get a Flowmaster 3" in - 3.5" out merge and get a muffler shop to build you a y-pipe. It will flow better and actually sound better. I had a Pacesetter Y-pipe on my car, and with a little hacking and welding, I added the Flowmaster merge.
Either way, stay away from the Pacesetter Y.
