Pace Setter LT Headers Problem
Old Aug 11, 2011 | 11:30 AM
dbombach's Avatar
Default Pace Setter LT Headers Problem
I found some long tube headers and ory pipe for about $320. And i know why. These headers don't have an air or egr hook up. Now I would delete these but I don't have a tuner. Now is there a way to weld some pipes together to make these work with my stock ls1. It has stock manifolds on. If you could help me out so I could get these on before the woodward dream cruise. Thanks
Old Aug 11, 2011 | 11:37 AM
SnakeEaterTA's Avatar
Just ditch your egr, your gonna have a CEL anyway when you delete your cats. Its the easiest thing to do and cleans up the engine bay nicely as well.
Old Aug 11, 2011 | 12:08 PM
dbombach's Avatar
I planned on blocking the O2 sensors. So my CEL won't be on 24/7. Which will be annoying, If i can't find a solution, Ill just get rid of air and egr.
Old Aug 11, 2011 | 12:19 PM
WS6SP33D's Avatar
Yeah just ditch the AIR and EGR. I would say you can put up with the cel until u get to a tuner. Good luck
Old Aug 13, 2011 | 01:12 AM
dbombach's Avatar
well i dont want to get rid of the air because it makes that POPPING noise that i love, but my neighbors dont haha. I have the gasket that goes to that tube on the exhaust manifold. I was going to make a template out metal, weld that to some pipe, and weld it to the headers. but i dont know where to drill the hole for the pipe. My car is a daily driver, so if i would match it up, it would be down. i dont know if this sounds like a good plan
Old Aug 13, 2011 | 02:39 AM
Canbarelygo's Avatar
your going through alot of trouble to make stuff you dont need work
Old Aug 13, 2011 | 02:57 AM
z99ls1's Avatar
Restricted User
Sounds like a bad plan. you need to get the car retuned since your taking out the cats. Delete the egr like everyone said and don't F**** up your headers for no reason. You need a tune with all ur adding and deleting so don't cheap out. Good luck
