For you guys bolting up Headers..
Old Aug 20, 2011 | 05:41 PM
2efnfast's Avatar
I know this is off topic, but OP, your forearms are kind of hairy, lol
(sorry, but for some reason I couldn't help but notice that, lol)
Old Aug 20, 2011 | 07:58 PM
the_merv's Avatar
Veteran: Air Force
Lol that's my man fur..25% Italian hairball.
I'm sure there a few threads on it..it's pretty easy to do. It doesn't hurt to get it out there from all of us that do it.
Old Aug 20, 2011 | 11:39 PM
01ssreda4's Avatar
You have hairy arms merv................
EDIT: treed......
Old Aug 21, 2011 | 01:32 PM
waxenate's Avatar
And the Mervster strikes again! lol!! I was wondering if that would work. Now for the newb question.....front and o2 sensors the same?
Old Aug 21, 2011 | 02:31 PM
RevGTO's Avatar
Pontiacerator
Yes they are.
Old Aug 22, 2011 | 04:11 AM
Mighty Whitey's Avatar
Nice write up. If I were running O2's, I'd definately be doing this.
Old Aug 22, 2011 | 06:51 AM
silverbeast's Avatar
I have a question for ya Merv. Just so ill have it straight in my head, when you say switch these wire locations i'm assuming there is a wire in each of these locations, right? Not an empty slot like some fuse boxes have.
Old Aug 22, 2011 | 08:07 AM
01ssreda4's Avatar
Basically plugging the rear wires into where the front are. Then the front 02s are being connected to the rear connectors. That way the rear 02 harness acts as the front. The computer doesn't know the difference.
Old Aug 22, 2011 | 02:25 PM
the_merv's Avatar
Veteran: Air Force
It's just switching 4 wires..the high and low signals for each sensor. The ground and power wires are all the same.
Just like Steve said..the PCM is reading the O2's as the fronts cause that is what the wires go to..you will be using the rear connectors in the Harness, but they are functioning as the primary O2's.
Old Aug 22, 2011 | 03:25 PM
_max_POWER's Avatar
I used this method when installing my longtubes and it worked GREAT. i read about it in another thread a while back.
Old Sep 26, 2011 | 04:22 AM
Grim Crow's Avatar
I know this is off-topic also, a little closer than the hairy arms thing though, but is there a reason you don't just make the front sensor wires longer? Like cut and solder? That's free, and you don't have to mess with the PCM, which isn't free...
from another thread:
Here's an except from a GM TSB that I came across today. Do you know if your PCM was ever disconnected?
"KIT (P/N 12167313) CONTAINS ONE CONNECTOR SEAL. WHENEVER THE CONNECTOR IS UNBOLTED FROM THE ALUMINUM BODY OF THE PCM, THE SEAL CAN STICK TO THE BODY, OR MAY BE TWISTED. THIS SEAL SHOULD BE REPLACED WHENEVER THE CONNECTOR IS REMOVED IN SERVICE."
...or just make extensions using junkyard camaro parts... it's what i'm doing
Old Sep 28, 2011 | 02:00 AM
  #32
TruBloodTransAm's Avatar
Very handy.
Old Sep 29, 2011 | 02:49 PM
  #33
HVYMTL's Avatar
I spliced extensions the first time... ended up not working so great. Next time I had my headers off I had new o2's and I went ahead and tried this. Super easy and works like a charm. So glad I didn't throw 40 dollars at extensions. I was nervous at first getting into the PCM but once I got over that it was cake. I'd recommend this to anyone doing headers/o2 sensors/extensions
Old Sep 29, 2011 | 03:47 PM
  #34
LS1WS6dreamer's Avatar
When I installed BBK LT's I didn't have to extend the passenger side, but I did on the drivers side. I didn't want to screw with the main harness and I extended the 02 sensor itself. No problems so far that I notice. Hell, the 02 sensor was 12 years old so if it didn't work it needed to be replaced anyways. I really didn't want to put new ones in before getting a tune anyways. Kinda rich after LT's and other mods. I will prolly buy Crovette Denso rear for the driver side and a regular F-body front for the passenger side. Maybe even the Bosch 13111's or whatever they are.
Old Oct 4, 2011 | 12:37 PM
  #35
WICKED_Z's Avatar
This is totally going to save me some money THANKS Merv!!!
Old Oct 4, 2011 | 01:26 PM
  #36
bobbo489's Avatar
Looks like I might be doing this shortly. Got a bracket fab'd up for my y-pipe and the stupid extensions were starting to melt to the headers.
Old Jul 12, 2012 | 03:53 PM
  #37
the_merv's Avatar
Veteran: Air Force
That would be GM's way of trying to get money...I've never had an issue with them seals.
Bringin this one up from the dead..
Old Jul 13, 2012 | 10:54 PM
  #38
KurtRardin's Avatar
Veteran: Marine Corps
Another one for the how-to archive. It's hard to keep up with you guys! If anyone sees a how to that was written in the last year then pm it to me. I've been away for about a year and have probably missed a bunch of good write ups. Even if you didn't write it, or you're unsure if I've seen it, assume that I havent and it'll get "stuck" with the rest of them in the archive.
Good write up!
Old Mar 17, 2014 | 04:55 PM
  #39
bsfrazeeWS6's Avatar
Originally Posted by the_merv
Ok here's some pics..
Find the PCM..that thing there in the corner.
Using a 7mm sized tool loosen the bolt in the middle of the top Connector..this is the blue Connector..
Remove the plastic guard..some are brittle..that's why this one is cracked..
If you look closely you can see the PIN Numbers above & below the wires..
Flip the Connector over and with a pic carefully remove the retaining clip..depress the little tab in the slot on each side of them and slightly pull..
To remove the Pin just push it forward a hair, then with your finger nail pull up on the tab..then pull the pin through the other side..
Then when you have the other one out just push it through and it locks in place. When you are finished put everything back together and you are done..
Here's the ones you switch again..
For 1998 F-body..
BLUE PCM CONNECTOR
SWITCH THESE WIRES
PINS:
1 <--> 5
2 <--> 6
41 <--> 46
42 <--> 47
For 1999-2002 F-body..
BLUE PCM CONNECTOR
SWITCH THESE WIRES
PINS:
25 <--> 26
28 <--> 29
65 <--> 66
68 <--> 69
If you notice in the pic I already have it done..that car is one of the guys that I live with..we just built it.
I did this today to my 98 ws6 and the car wouldn't start when I got done. Swapped them back to the way they were and still nothing. Any ideas?
