For you guys bolting up Headers..
Old Aug 19, 2011 | 02:24 PM
the_merv's Avatar
Veteran: Air Force
Default For you guys bolting up Headers..
This is something that I've been doing and it's worked flawlessely..figured I'd throw it out there to help out..
Instead of using the POS Extensions that you get for/with the LT Headers I've been re-wiring the rear O2 Sensor Connectors to be the primary ones, then clipping the front two Connectors off.
For 1998 F-body..
BLUE PCM CONNECTOR
SWITCH THESE WIRES
PINS:
1 <--> 5
2 <--> 6
41 <--> 46
42 <--> 47
For 1999-2002 F-body..
BLUE PCM CONNECTOR
SWITCH THESE WIRES
PINS:
25 <--> 26
28 <--> 29
65 <--> 66
68 <--> 69
Since most of us do LS1 F-bodies this will help out alot..it saves $50 on extensions that you burn up a month later..lol
If I can get ahold of the PCM diagrams for C5 & C6 Corvettes, and LT1 Cars I can put that info out here too.
Old Aug 19, 2011 | 03:18 PM
sjsingle1's Avatar
my extensions work fine.......that would be a PITA to do
Old Aug 19, 2011 | 03:47 PM
the_merv's Avatar
Veteran: Air Force
Thanks for the input.
Now for those of us that like to get our hands dirty & think outside the box it takes 10 min to do and saves $50..so take it fwiw when you burn your extensions..
Old Aug 19, 2011 | 04:07 PM
1badWS6's Avatar
There is a detailed write up on this somewhere. It isn't that hard to do either. If someone could link it, that'd be great cause searching the mobile forums sucks.
Old Aug 19, 2011 | 04:20 PM
senicalj4579's Avatar
Well thats one way to do it. Nothing wrong with that and I like the "get your hands dirty" thing lol.
I just use the vette o2s myself.
Old Aug 19, 2011 | 04:49 PM
JohnS Z28's Avatar
yeah pictures say more than words...=)?
Old Aug 19, 2011 | 05:07 PM
the_merv's Avatar
Veteran: Air Force
I dont know how much more detailed you can get..lol..unbolt the Blue PCM Connector, take the clip off and pop the wires out..
I'll do it here in a little bit..I'll take pics..
Old Aug 19, 2011 | 07:37 PM
TankTheTurtle's Avatar
took me all of about 10 minutes, and that was with a drink in my hand
Old Aug 19, 2011 | 07:42 PM
Are you gonna hold his hand to?
Old Aug 19, 2011 | 10:51 PM
1badWS6's Avatar
I'm saying there's already one made lol. It's around somewhere, I'll try and find it.
Old Aug 20, 2011 | 10:46 AM
the_merv's Avatar
Veteran: Air Force
.. if there is one then I guess there is one..if it takes a min to find it then I guess what I put out will suffice for now..lol.
Old Aug 20, 2011 | 11:13 AM
the_merv's Avatar
Veteran: Air Force
Ok here's some pics..
Find the PCM..that thing there in the corner.
Using a 7mm sized tool loosen the bolt in the middle of the top Connector..this is the blue Connector..
Remove the plastic guard..some are brittle..that's why this one is cracked..
If you look closely you can see the PIN Numbers above & below the wires..
Flip the Connector over and with a pic carefully remove the retaining clip..depress the little tab in the slot on each side of them and slightly pull..
To remove the Pin just push it forward a hair, then with your finger nail pull up on the tab..then pull the pin through the other side..
Then when you have the other one out just push it through and it locks in place. When you are finished put everything back together and you are done..
Here's the ones you switch again..
For 1998 F-body..
BLUE PCM CONNECTOR
SWITCH THESE WIRES
PINS:
1 <--> 5
2 <--> 6
41 <--> 46
42 <--> 47
BLUE PCM CONNECTOR
SWITCH THESE WIRES
PINS:
25 <--> 26
28 <--> 29
65 <--> 66
68 <--> 69
If you notice in the pic I already have it done..that car is one of the guys that I live with..we just built it.
Old Aug 20, 2011 | 01:28 PM
bene's Avatar
Trunion King
Nice one man.
Old Aug 20, 2011 | 01:40 PM
Great pics and details man.
Old Aug 20, 2011 | 03:10 PM
1badWS6's Avatar
So this just allows you hook up the rears then and it tells the pcm that its running the fronts?
Old Aug 20, 2011 | 03:18 PM
msydow's Avatar
hmmm. i believe i'll be saving this info and using it as my own...nice write up.
Old Aug 20, 2011 | 03:43 PM
bene's Avatar
Trunion King
yes.
Old Aug 20, 2011 | 04:04 PM
the_merv's Avatar
Veteran: Air Force
Yup..what were the Rear O2 Connectors are now wired to be the Front O2's. Then you clip the front Connectors on the Harness to avoid confusion.
It might take more time to do this than to just run an extension..but the way I see it is the wires are there so might aswell use them & save money.
Old Aug 20, 2011 | 04:29 PM
TheBlueKnight's Avatar
Damn, could have saved me $40. I'll tell my bro about it! Thanks a lot!
Old Aug 20, 2011 | 05:15 PM
Mumbles's Avatar
Here is the first thread where I learned of this...
https://ls1tech.com/forums/generatio...g-install.html
Post #14.
This is really good info to have and there are mutliple threads that include it. Just do a search for "PCM Pins".
