ported 241 heads?
Pending if I decide its better to buy 243 heads. If I don't have to replace them. Then I want to get a new converter and cam. I'm also putting my full true dual set up with long tubes.
Also, AI = Advanced Induction
What cam are you running? I only ask, because depending on the cam, 243 heads may put the valves too close to the pistons.
I have done extensive research into various ways of making power while still retaining a stock or near-stock visual appearance, and passing the CA sniffer.
That includes calling/e-mailing Patriot and asking if they can port 241s. They do not do 241 casting heads. They do other stock castings, but not 241s (although, I'm pretty sure they used to).
WCCH used to do CNC 241s back in the day but there are very little out there, and they have no dyno results from them. When I contacted WCCH, he said the guy who did the programming for 241s and a couple other stock head castings left the company and took the CNC programs with him, so WCCH no longer does 241s either.
I only had three options for porting my 241s:
- DIY
- Have a local head porting guy do it in an undefined amount of time for $700
- Send it to Advanced Induction
I chose none of the above and just threw on a set of milled 241s due to time/money constraints.
CnC on stock castings runs 650.00 with cutting seats and engraving .We also stock valves of all sizes.
We can also help you out with cam and spring choice
Chris 909-291-7550
www.cbmmotorsports.com
Chris 909-291-7550
I just want flow numbers and dyno numbers (if you have any).
thanks Chris
I know nothing about ^^^^ so I can't comment. However, I know AI is the place to go if you want the power out of them.
CBM 241 as cast (unmodified)
Lift / Int / Exh
0.100 / 75.1 / 54.3
0.200 / 143.5 / 95.3
0.300 / 183.4 / 125.0
0.400 / 209.2 / 155.4
0.500 / 217.3 / 182.3
0.600 / 227.1 / 196.7
0.650 / 230.7 / 202.7
CBM 241 CNC
Lift / Int / Exh
0.100 / 55.4 / 61.9
0.200 / 116.7 / 113.1
0.300 / 178.8 / 149.0
0.400 / 235.1 / 178.2
0.500 / 269.6 / 200.3
0.600 / 295.2 / 211.5
0.650 / 305.4 / 215.1
AI 241 as cast (unmodified)
Lift / Int / Exh
0.100 / 65.9 / 55.2
0.200 / 139.3 / 101.5
0.300 / 192.8 / 135.7
0.400 / 215.5 / 160.1
0.500 / 226.1 / 171.2
0.550 / 230.6 / 175.9
0.600 / 233.2 / 179.7
0.650 / 236.5 / 181.3
AI 241 219cc CNC
Lift / Int / Exh
0.100 / 65.6 / 54.1
0.200 / 143.5 / 101.2
0.300 / 208.1 / 144.1
0.400 / 251.2 / 173.7
0.500 / 270.7 / 197.5
0.550 / 277.2 / 203.5
0.600 / 284.9 / 209.5
0.650 / 285.8 / 211.8
I appreciate the flow charts!
As far as the mods I am doing. Im installing hooker l/ts, custom x pipe, and spiral flows, new lid, ported throttle body, smooth elbow, and maybe a manifold if I find a decent priced one. But I am wanting to do a ASA cam and a 3200 stall converter.
