LQ4 crossover coolant pipes
Old Aug 22, 2011 | 07:19 PM
jks67ss396's Avatar
Default LQ4 crossover coolant pipes
Hey guys
Im putting my lq4 back together and need to know what to get...
Do i just get 4 little gaskets for the crossover?
GM part 12551933
or do i need:
12551933 engine coolant air bleed pipe seal, two required LQ4.
12602540 engine coolant air bleed pipe cover, two required LQ4.
Ive heard multiple versions...
and just to be sure, i can reuse the crossover pipes, right?
thanks!!
Old Aug 22, 2011 | 07:33 PM
99C5Coupe's Avatar
I just ordered and received 12551933 from RockAuto, they are the coolant crossover gaskets and come four in a package, I ordered four of course. Mine is LS1 so I don't know what LQ4 will need.
Old Aug 22, 2011 | 07:35 PM
Old Geezer's Avatar
My 05 LQ has 2 block offs at the rear and the pipe at the ft. The seals are the same for all 4 locations...
Old Aug 22, 2011 | 07:36 PM
jks67ss396's Avatar
so it sounds like i need one order of 12551933, and that will do all 4 corners?
thanks gentlemen!
Old Aug 22, 2011 | 07:39 PM
99C5Coupe's Avatar
Yes sir, that is correct.
Old Aug 22, 2011 | 07:46 PM
jks67ss396's Avatar
hmmm
so it seems that DORMAN Part # 56390 contains 4 of these guys, but the 12551933 part number is per seal, so id need 4 of them at 5-7/each....
I think ill stick with the dorman
Old Aug 22, 2011 | 08:25 PM
99C5Coupe's Avatar
Originally Posted by jks67ss396
hmmm
Yes, Dorman 56390 is the same as 12551933, both are 4 per package of 1
