Need some suggestions!
Thanks
im talking about external engine... not messing with the internals, its my daily driver, just a nice street car, also the engine has a 100,000 mile warranty so im just looking for bolt ons
Fast intake and throttle body
1 7/8 headers with a flowmaster merge 4" I pipe cutout reduced down to 3" choice of muffler
Chrs1313 RAM air
Larger lid and maf
Electric water pump
Underdrive pulley
Technically heads are not internal like a cam... If you can do heads without a warranty I would do some afr 205s with some rockers
That should get you very close to tor goal and make a nasty bolt on car, or bolt on with heads.
Whayy exactly is a underdrive pulley? i have always wondered that
also what is Chrs1313 RAM air? ive got the oem ram air, and a mti lid, but im looking for a slp lid and bigger maf.
also I had a diablo sport tune on my old motor, what is y'alls position on diablos tune? and would i get better power if i took it to get dyno tuned, i live in thibodaux la now but near were i used to live there is a place called hennesy that does dyno tuning.
also how much quicker would it be if i put 4.10's in it, i know it doesnt add hp, but would it make a difference in quickness? i have 3.42s
thanks in advance
thanks in advance
Speed Inc. sells them on their site. It is just an aftermarket ram air, best on the market actually.
Don't do a Diablo, get a dyno tune.
410s would make a big difference for a manual. Unless your going to a larger diameter lid, I wouldn't worry about switching unless you just like SLPs lid better. They all make the same power.
so is the chrs1313 like the slp cold air kit? were it directs the air into the airbox?
so i would achieve some quickness from dropping to 4.10's? because i have a leaking pinion seal (go figure) and i was going to replace that anyways, plus the rear end has a small ammount of slack in it.
basically i am asking if dropping to 4.10's would be worth the money? i have a pretty BA t56. pro 5.0 and better forks and all the goodies...supposed to be built for 900hp.
The Chrs1313 is similar to the other ram airs, like the SLP... But it is superior. It has proven to pick up nearly 1 mph over the other ram airs. If you buy one, get the Chrs1313.
I spoke with my buddy at the local gm dealer and he said as long as its N/A and nothing is changed in the internals it should stay in warranty. hope he is correct
