removing 6.0 from denali
Old Aug 27, 2011 | 09:39 AM
87F-bomb's Avatar
Default removing 6.0 from denali
alright so my girlfriends dad wrecked his denali and is letting me have the 6.0 as long as i pull it my self what all do i need to remove with the motor and where are they located . i searched the forums and could only find discussions of wich way to pull them. any help would be apreciated
Old Aug 27, 2011 | 11:25 AM
RARON455's Avatar
Take the engine, all the accesories (they are bolted on the engine,, You wont need the exhaust, That will get you what you need, If he is letting you take whatever you want,, I would also take the trans out of the truck also, Take it as a complete drivetrain, Even with the computer.
Old Aug 27, 2011 | 11:36 AM
01ssreda4's Avatar
If your are asking this question perhaps you should enlist the help from someone who has removed an engine before.
Old Aug 27, 2011 | 12:05 PM
retardedpenguin's Avatar
You have to learn some how..
It's not too hard. Disconnect the transmission, motor mounts, lines, and harness from the body.
Old Aug 27, 2011 | 12:11 PM
RARON455's Avatar
^^^^Yup I have always found the easiest way to do something is to jump in it with both feet,, But then again, I am a maintenance mechanic..
Old Aug 27, 2011 | 02:59 PM
Chris10an's Avatar
Hello. What you need to take out and reuse, is the wiring harness, ecu, Maf sensor, Tac module with wiring and pedal "if electric throttle" if you don't use this, you can sell it on Ebay for about 300 bucks.. What you don't want to use is that intake. You can use the new one from Edelbrock, that way you can use all the truck accessories. Looks cool and give you some extra hp with a tune...
Old Aug 28, 2011 | 01:57 PM
87F-bomb's Avatar
thanks guys iv taken out a few carbed motors nothin special but knew this would be a different kind of animal. the trucks pretty totaled so this should be pretty fun
Old Aug 29, 2011 | 07:59 AM
Paul Bell's Avatar
That's MISTER MODERATOR
What are you planning on doing with this motor?
As you've done a few engine pulls before, you know you need a good shop grade floor jack, jack stands, engine hoist, friends with beers, a full rolling toolbox, a radio for tunes/games, a moving dolly, drain pans, understanding girlfriend/wife......
