trick flow heads
Old Aug 30, 2011 | 01:04 PM
00'blkss's Avatar
Default trick flow heads
whats the biggest cube motor these are good on? thanks for any help
Old Aug 30, 2011 | 01:20 PM
slydwys's Avatar
Depends on the size of the head.
Old Aug 30, 2011 | 01:24 PM
NC98Z's Avatar
They make different models for different sized motors. Some have little 346 cathedral ports and some have big rectangular 427 ports. How much money you got? If You've got the cash I'm sure they've got the heads.
Old Aug 30, 2011 | 01:32 PM
00'blkss's Avatar
i bought them a while back and have been running them on my stock bottom end motor, but io want to go to a 408 cid and was just wondering if these will work or i need to cosider new heads. i did buy them new and cant find the info on them so.. the only thing i knowq about them is they are 215's
Old Aug 30, 2011 | 01:39 PM
Darkman's Avatar
The 215s are designed for smaller motors, but they can be reworked for larger cubes. Call Total Engine Airflow.
Old Aug 30, 2011 | 01:53 PM
00'blkss's Avatar
thanks for all the advice
Old Sep 6, 2011 | 08:44 AM
TrickFlowTech's Avatar
LS1Tech Sponsor
Good advice. On a 408 I would look into the 235cc head.
__________________
Old Sep 6, 2011 | 08:55 AM
KC&97TA's Avatar
Alot of guys running TFS 225's on 402/408 engines, 235's would be more like it
TEA will work them to what you need, I have a pair of TEA 243 stage 2's on a 225 runner/61cc chamber works well with a 232/234 cam 404cu engine
