Fatty Injectors on the 102 can be done!!!
Old Sep 19, 2011 | 10:13 PM
RaVagE's Avatar
Default Fatty Injectors on the 102 can be done!!!
According to the guys over at Thunder, it can be done without modification. The pics below do the justice. There have been a lot of set-ups at which they have done this to without any issues. Pictured is an LS1/LS6 102 with racetronix 42#, and LS2 fuel rails. I do notice however, that there are no spacers, but there are a good amount of thread left in the bolt where the spacer would go.
Old Sep 20, 2011 | 10:23 AM
XtraCajunSS's Avatar
The reason that there are no spacers is because we were just testing this on the dyno to make sure the injectors would work. FWIW, one of my guys thought they wouldn't work until I went back and worked out the solution. If you seat the injectors with the PROPER lower o-rings, you will find, they don't go very deep and there are no clearance issues. Spacers are now in place...
Hope this helps,
Shane
Also, this setup was smoke checked for vacuum leaks and none were found.
Old Sep 20, 2011 | 07:57 PM
RaVagE's Avatar
Well said Shane, Thanks.
Old Sep 21, 2011 | 08:18 PM
bayer-z28's Avatar
Hope this helps,
Shane
My uppers were the problem even with the supplied FAST o-rings. As soon as I primed the pump it sprayed enough fro me to see it over the cowl. Tried twice and it was leaking from the rails on both attempts. The angle was off. Maybe it's something about the LS3 rails he's using that is the key.
I thought the angles on the bottoms looked fine.. The tops must have been unhappy for some reason.
Old Sep 23, 2011 | 12:19 PM
04stangkiller's Avatar
interesting I could never get mine to seat properly but I was using the spacers. I ended up having to massage the manifolds injector seats for them to fit down all the way with no vac leaks.
