coolant crossover pipe bolt sizes
Old Sep 22, 2011 | 12:38 PM
jks67ss396's Avatar
Default coolant crossover pipe bolt sizes
Hey guys,
Im looking for some clarification on what size bolts i need for the rear crossover plugs and the front crossover pipe.
Heres some info i found here
LS1 rear coolant bolts (on back of heads) (HFH m6x1x30) = 11516425 (formerly 11514008)
LS1 coolant bolts for front pipe = 12561089
LS1 coolant crossover pipe = 12562169
So are the bolts for the back plugs actually different between the front and back?
And, are these part numbers actually correct? 11516425 and 12561089
And, cant you guys tell me the bolt sizes? m6x1x30 on back? and on front?
thanks
Old Sep 22, 2011 | 01:05 PM
MeentSS02's Avatar
Kleeborp the Moderator™
The front bolt size is correct - I just measured the stock ones on my LS1 the other day, and that's what I came up with. I've never looked at the rears on mine though, so I can't say for sure if the bolts (or studs as they are on mine) are the same back there, but I can't imagine them being different seeing as how the heads are mass produced - it would make more sense to make the hole diameter, depth, and thread pitches identical front and rear.
Old Sep 22, 2011 | 01:56 PM
jks67ss396's Avatar
Hey Steve
So, the front is m6x1x30?
i cant imagine front/rear being different either...
thanks
Old Sep 22, 2011 | 02:37 PM
MeentSS02's Avatar
I'll double check the measurements when I get home, but it was definitely an M6 x 1.0, and it was pretty long, so the 30mm length looks correct to me.
Old Sep 22, 2011 | 02:39 PM
jks67ss396's Avatar
thanks man
ive got 3 30mm bolts and 4 40mm bolts. (measured total length.. thread + head)
might be missing one of the 30's and the 40s look like they will work, but im sure ill need them for something else...
again, thanks for all your help
Old Sep 22, 2011 | 06:17 PM
sjsingle1's Avatar
used 30mm front and back on mine
Old Sep 22, 2011 | 06:34 PM
jks67ss396's Avatar
30 mm under the head or total overall length?
thanks!
Old Sep 22, 2011 | 06:36 PM
sjsingle1's Avatar
all bolts are measured under the head
Old Sep 22, 2011 | 06:38 PM
jks67ss396's Avatar
just making sure
thanks!
Old Sep 22, 2011 | 08:24 PM
MeentSS02's Avatar
I measured 34mm under-head length on the stock studs, so 30mm will be a little shorter, but should still have plenty of thread engagement.
Old Sep 22, 2011 | 10:36 PM
Paul Bell's Avatar
That's MISTER MODERATOR
The front and rear threaded holes in the heads are identical.
Retain and use the coolant tubes to the back of the heads. The rear cylinders can use all the cooling help they can get.
Old Sep 22, 2011 | 10:50 PM
jks67ss396's Avatar
its actually an lq4, so i have the plugs in the back and the pipe up front
Old Sep 22, 2011 | 11:06 PM
sjsingle1's Avatar
you can put a LS6 pipe in the back........i did
Old Sep 22, 2011 | 11:13 PM
jks67ss396's Avatar
does it work with the lq4 truck intake?
Old Sep 22, 2011 | 11:18 PM
sjsingle1's Avatar
i am sure it has the same clearances as the LS1 and LS6 intake..........no?
sjsingle1's Avatar
Old Sep 22, 2011 | 11:24 PM
jks67ss396's Avatar
so wheres the steam bleed off in the back? in there a line that goes up to the radiator/pump/intake that i cant see in the pic?
Old Sep 22, 2011 | 11:36 PM
sjsingle1's Avatar
it simply goes from left head to right head......did not bother to hook it into the front line......figured it was better than block offs
