PCV help please!!!
Old Sep 22, 2011 | 08:30 PM
DOG-TWO's Avatar
Default PCV help please!!!
I broke a little piece of vacuum hose when removing my intake for a swap. I don't know what the piece is called. It is the little piece connecting the two lines running from the throttle body and passenger side valve cover into the hose that runs into the PCV valve on the driver's side valve cover. Does anyone know what this is called or where I can get one? Thanks.
Old Sep 22, 2011 | 08:35 PM
omarrakeen's Avatar
lol same exact issue here, you can look it in my thread down there. buying new gm piece will cost around a 100$. so you can either move to a catch can, use breathers OR buy plastic joints or piece of fuel line hoses and connect them. good luck.
Old Sep 22, 2011 | 08:40 PM
DOG-TWO's Avatar
haha i have read some of your threads and thought it was pretty funny that we've broken the same things lol. but yeah do you have a link to this part by chance?
Old Sep 22, 2011 | 09:46 PM
sjsingle1's Avatar
or get a LS6 valley cover..........
Old Sep 22, 2011 | 09:54 PM
DOG-TWO's Avatar
Does that vacuum line run into the valley cover on the ls6 or what?
Old Sep 22, 2011 | 11:17 PM
sjsingle1's Avatar
only 1 hose is needed
Old Sep 23, 2011 | 05:01 AM
omarrakeen's Avatar
now t hat looks clean! will it fit directly? i heard theres some grinding but am not sure.
Old Sep 23, 2011 | 07:59 AM
Paul Bell's Avatar
That's MISTER MODERATOR
dogtwo, WHAT YEAR IS YOUR CAR??
Have a look here:
https://ls1tech.com/forums/14407744-post5.html
Old Sep 23, 2011 | 10:32 AM
redbird555's Avatar
If you were lucky enough to get an ls6 block in 01-02 then the cover literally just bolts on no issue. If not then you have to use a dremel and grind a small tab off your ls1 block under the cover its no big deal and can be done with a dremel in about 10 minutes.
Old Sep 23, 2011 | 10:38 AM
sjsingle1's Avatar
i used a dremel and a hammer
Old Sep 23, 2011 | 02:40 PM
omarrakeen's Avatar
98 here..not bothering with this. thanks for the pic and sry for the hijack op
Old Sep 23, 2011 | 09:31 PM
sjsingle1's Avatar
best mod i ever did
Old Sep 24, 2011 | 03:19 PM
DOG-TWO's Avatar
Have a look here:
My TA is a 98.
Old Sep 24, 2011 | 03:32 PM
Paul Bell's Avatar
Cool. Make up a sig with your car & mods in it.
Did the link help you out?
Old Sep 24, 2011 | 03:48 PM
DOG-TWO's Avatar
Yeah I will eventually when I get around to it. I looked at that picture a couple of times for help since I started my swap even though it's a tad bit different than mine I think.
Old Sep 24, 2011 | 05:26 PM
Paul Bell's Avatar
Yes, there are some differences between the 98 F-body and 99-up F-body PCV pipes.
For 98 ONLY, the GM number is 12560692. $97.91 at Parts Taxi.
For 99 and up, 12590632 is $81.29.
When you need GM parts, Parts Taxi is good and they don't add ridiculous shipping & handling charges.
http://www.partstaxi.com/splash/index.cfm?siteid=215330
Old Sep 24, 2011 | 09:56 PM
sjsingle1's Avatar
parts taxi is good? the other GM parts place charges out the *** for shipping
Old Sep 24, 2011 | 10:06 PM
owndjoo's Avatar
whered u get that egr blockoff?
Old Sep 25, 2011 | 12:54 AM
Paul Bell's Avatar
GM part number 12558346.
Old Sep 25, 2011 | 11:41 AM
DOG-TWO's Avatar
Thank you for the info!
