Egr freeze plug
Old Sep 23, 2011 | 11:42 PM
bones_c's Avatar
Default Egr freeze plug
So I did the !egr and use a 1 3/8" freeze plug as directed... Sounds like it's letting in air? Your thoughts?
Old Sep 24, 2011 | 03:34 AM
00NBMformula's Avatar
Mine sounds like it whistles at me to every now and then, id like to find something else too
Old Sep 24, 2011 | 05:17 AM
omarrakeen's Avatar
am sure if it leaked car will run very bad! my egr was letting air the other day and car was undrivable.
Old Sep 24, 2011 | 05:33 AM
bones_c's Avatar
It seems like it's only when I hit the throttle though... Is this sound I hear just a mass of air rushing through te intake?
Old Sep 24, 2011 | 12:36 PM
my Freeze plug fell out the other day and was sitting on my intake(SITTING!!) but my car ran almost normal for some reason, and thats a huge vacuum leak lol..
OP if its only when you mash the gas I would guess its just air being rushed in, gets louder when you replace the lid since your removing the baffles
Old Sep 24, 2011 | 01:04 PM
Pocket's Avatar
You installed it wrong if its leaking
Im boosting a LS1 intake using the plug with no issues or leaks
Old Sep 24, 2011 | 03:55 PM
How is 1 supposed to install a expandable rubber freeze plug??
i thought u stuck it in dry and tightened it up, but if u tighten too much it pops out.
waiting for a thats what she said
Old Sep 24, 2011 | 05:32 PM
bones_c's Avatar
That's what she said haha but I was thinking the same thing.. They don't make an actuall plate that bolts in there with a gasket?
Old Sep 24, 2011 | 06:20 PM
omarrakeen's Avatar
^ there is. search it up on some sponsors on here or look it up on ebay.
Old Oct 3, 2011 | 03:03 AM
bones_c's Avatar
yea i orded one from speed inc when i got the block off plate kit but they didnt put it in the box... so i went to oriellys and got the freeze plug. i just wasnt sure if they make something like a plate because i cant find any pics on websites.
Old Oct 4, 2011 | 12:43 AM
bobbo489's Avatar
Stupid question here, but how is one supposed to put the freeze plug in the and make it stay? I couldn't figure it out so I set it on the hole then took some JB Weld and well secured it over the hole. Was that a good or bad idea?
Old Oct 4, 2011 | 07:08 PM
Pocket's Avatar
Push it all the way in and tighten until it cant slide out. You'll have to hold it to keep it from spinning while torquing
JBweld is a bad idea next to a highly flexible rubber
Old Oct 4, 2011 | 07:56 PM
s346k's Avatar
i've used that plug on my car for the last 4 years haha.
how hard is it to install an expandable plug? really? i even removed the tb and looked inside the intake (thinking it might be in too far and restricting/upsetting airflow) and that's not the case either.
why on earth you'd give anyone more than the price of one of those plugs for deleting emissions is beyond me. i used pennies for my blockoffs and that $2 plug in the intake. been in there for 4 years/25k miles.
Old Oct 5, 2011 | 12:12 AM
bobbo489's Avatar
yeah, I got the metal one instead of the rubber type one, so I set it on top and welded it. It seems to be working fine, and I don't think I am gonna be able to get it off anymore.
Old Jan 25, 2012 | 05:47 PM
SF 1HOTLS1's Avatar
ws6 store .com sells the egr plug you guys are looking for. its 25 bucks tho and is why some ppl just go with a freeze plug. imo i would change the washer on the freeze plug though. the one that comes with the 1 3/4 plug is some what small. if your at wot and that plug gets sucked in say goodbye to your engine!
Old Jan 26, 2012 | 03:03 AM
NemeSS's Avatar
Ive always used the metal plugs. Either the 35mm or a 1 3/8 metal or brass freeze plug.
Just lay square in the bore and tap squarely in place. Makes a good tite lasting seal when installed correctly.
Old Jan 26, 2012 | 01:18 PM
99 Blue Bird's Avatar
+1. you guys are over thinking this. put the metal freeze plug in and forget about it. no need to tighten or use a sealent to keep it tight. the freeze plug itself will be air tight.
Old Jan 26, 2012 | 01:46 PM
ssteven's Avatar
I have this. Looks nice also.
http://www.ebay.com/itm/LS1-EGR-Bill...sories&vxp=mtr
Old Jan 26, 2012 | 03:30 PM
sepsis's Avatar
Originally Posted by ssteven
That's a nice piece there.
