Some Food For Thought!
Old Oct 4, 2011 | 01:42 PM
RaVagE's Avatar
Lightbulb Some Food For Thought!
With my build project right around the corner I have been running a lot of stuff through my head. An area that came to my concern, was this FAST 102/102 set-up. So since the the opening of the fast is 102 mm, the intake mid pipe between the lid and TB will be a 4inch piece(~102mm) and an FTP lid 104mm everything looks fine and dandy right? So if I do a simple area calculation of a round pipe at 102mm I get 12.56 inches(3.14(pie) x ~4in(Diameter)). Since my car is an SS I started to look at the induction opening of the lower airbox. That measures at 15.5inches long and .5inches tall, with an area of 7.75inches. So you can see where I am going with this. The simple bottle neck now lies further upstream from the intake. With this being said, would it be safe to say, that if I want a max performance induction set-up that I would have to look into the Chris1313 set-up? I believe this is why his piece and others see good results because of this bottle neck I mentioned above.
Old Oct 6, 2011 | 01:20 PM
chrs1313's Avatar
you are right on track...nice observation...
The inlet is a bottle neck...let it breath from below...
