Where does this go (pic)
Old Oct 8, 2011 | 06:38 PM
My6speedZ's Avatar
Default Where does this go (pic)
When putting her back together i found this bad boy and Its been a while since I took her apart. Anyone know where this goes?
Old Oct 8, 2011 | 06:56 PM
outkast6991's Avatar
pass side firewall to back of the intake? thats my guess
Old Oct 8, 2011 | 08:18 PM
My6speedZ's Avatar
great i'll give it shot tomorrow thanks
Old Oct 8, 2011 | 08:49 PM
NSSANE02's Avatar
Yup. It's for the HVAC controls I think.
Old Oct 9, 2011 | 12:24 AM
RedRallyeZ's Avatar
Nailed it. Its a vacuum line for HVAC. common problem that that line will crack, so be gentle putting it back in.
Old Oct 9, 2011 | 10:46 AM
got milk??'s Avatar
If it cracks you can get replacement tubing from Autozone or Lowes. Reuse the T fittings/Angles etc.
Old Oct 9, 2011 | 11:56 AM
omarrakeen's Avatar
out of curiosity what year is your car? i didnt find this in my 98..
Old Oct 9, 2011 | 01:36 PM
94'BLKBRD's Avatar
^^^^2000
Old Oct 9, 2011 | 02:14 PM
omarrakeen's Avatar
^ yep, my 98 has a straight pipe that goes to the intake from near the pcm..
Old Oct 9, 2011 | 06:42 PM
My6speedZ's Avatar
Originally Posted by 94'BLKBRD
^^^^2000
Yes, it's a 2000
Old Oct 9, 2011 | 07:22 PM
patSS/00's Avatar
It goes between the back of the intake and the AIR solenoid on the driver's side, which is the small solenoid attached to the intake with a bracket. (There's another thin line from that solenoid to the big AIR valve in back against the firewall.)
The other connection on that T is for the line to the pass. side that goes to a Y, one side of that for HVAC.
Old Sep 24, 2012 | 02:40 PM
oxblood!z28's Avatar
Default Is it important?
I'm bringing this back just because I may have not installed my intake correctly. A FAST 102 was put on by me, and I didn't connect that line to the back of the intake. I left it out because I'm no longer have the EGR and AIR in the car. The nipple on the back of the intake is currently connected to a vacuum line that may have possibly connected to the end of the T fitting vac line. At least that my guess, but my question is is that T fitting vac line needed?
thanks you guys
Old Sep 24, 2012 | 06:11 PM
Anybody know if that vacuum hose is needed?
Old Sep 24, 2012 | 06:54 PM
sjsingle1's Avatar
only if you want your HVAC controls to work
Old Sep 25, 2012 | 10:25 AM
thanks man...just for reassurance this wouldn't cause ideal or tuning issues right?
Old Sep 25, 2012 | 01:32 PM
nomasterase's Avatar
as long as its not left as an open vacuum leak you shouldnt have any issues
