LS6 intake, 04+ valley cover, LS1 4-1 coolant lines. Fit?
@ 66_BADBOY - THAT is EXACTLY what I needed, thanks! I am currently at the stage of fitting the coolant pipes back on, but finding it doesn't clear the PCV nozzle. Did you have to heat the pipes up to bend them so much? Mine looks almost completely different from yours...
No heat. Just take it slow. You'll find that you have to make some crazy shapes because once you dodge something, you have to make up for the distance that is left in the tubes (fixed endpoints means the space in between must be adjusted). Kinda tricky, but you'll get it.
The following users liked this post:
Homer_Simpson (08-02-2023)
